10,097 Registered Users
Topics7,432
Posts41,135
Members10,097
Ex Chief
Ex Chief
I posted the following in the schematics section but I also wanted to post it here if that's allowed
Hi
We have been contacted to remove an old platform lift in a stage. It is a Cemco unit with an in ground jack and an ESI controller. It is equipped with electromagnetic brakes that keep the platform from drifting while not in use. Does anyone have the schematics for this type of brake or is there a manual way to lift the brake.
Thanks in advance for any help
Chris
See attached pic
Chris Kenlan
A brake coil is just a coil, it just needs current to flow to magnetize. If you power it with the right voltage to cause the current to flow, it will lift. I would just manually apply the right voltage to the coil and unbolt the thing and take it off first. Take a look at the coil and see if it has the voltage on it, you can use a transformer and rectifiers if necessary to create whatever voltage you need. I'd wire it in with a switch to have easier control of it.
If you don't have prints to make the connections in the controller you can wire directly to the brake coil in its junction box under the car.
Make sure the hydraulic system is holding before you do release it.
Ex Chief
Ex Chief
Thanks for the info, that's what i will do if I don't get any further with the prints. The good thing is the styles extend past the brakes, we will use rail blocks under the shoes before I lift the brake. safety first!
Chris Kenlan
Ex Chief
Ex Chief
With a little persistence I came across the old schematics. See attached, Thanks for your suggestions!!
Chris Kenlan
S Online: Content
That APPEARS to be a Southeastern unit not a CEMCO.
PHP: 8.3.37 Page Time: 0.038s Queries: 26 (0.011s) Memory: 3.0205 MB (Peak: 3.5946 MB) Data Comp: Off Server Time: 2026-11-25 02:00:43 UTC
