#3208 04/12/12 09:02 PM
I'm looking for the power supply requirements and voltages needed on the signal inputs to this operator. I haven't found much on the Unitec site.
Hi The imotion operator has two types of boards imotion 2 (ABA26800AED1)
30DC Input to DOBD @ P6-2
30DC Input to IOBD @ P12-2
120vdc input @ PSSB P8-1 TO P8-3
ACheck fuses F19/F15/F9
Should have 120 vdc at terminals 143 &142
Elev8erman
25 year Otis Adjuster
Thanks for your help on this. I am working with a Cetek controller and want to make sure I have the right set up on the I/O and power supply.
fixdething
40 year industry experience
otis makes a imo2 retrofit kit to adap different controllers to the imo2. the imo is easy its only looking for 3 signals on a typical install. do, dc and /ndg. if you pull the do or dc signal to ground it will do that function and all slowdowns stops etc. on its own after setup. they like to have to dc grounded while the car is moving. /ndg needs to be grounded all the time for normal op, unground and it will go into nudging, same for /hvydoor.
PHP: 8.3.36 Page Time: 0.067s Queries: 22 (0.008s) Memory: 3.0128 MB (Peak: 3.5932 MB) Data Comp: Off Server Time: 2026-11-05 18:40:19 UTC
