0 members (), 36 guests, and 2 robots.
#35205 05/04/23 08:47 PM
Hi. I got a dry belt Tac 20 with I2 valve under tank leaking from the big leveling adjuster. Can I thread that all the way out and replace it ?
Jluff #35207 05/04/23 09:19 PM
Measure how far out the adjustment is now. Take the two bolts holding its plate to the valve body. Pull the whole thing out, replace o ring.
Jluff #35208 05/04/23 10:25 PM
That’s a no, it won’t thread out. If the filter is clean you can just replace the o-rings but it’s usually no. Best to keep a couple of the up level adjusters on your truck so you can swap the whole thing out. They’re not very cleanable. Part number 9729124.
Jluff #35209 05/04/23 11:25 PM
V Offline
Good idea keeping some spare up adjusters they seem to leak and plug often. I also had a spare plate that they screw into so that I could swap it as an assembly and not worry about much oil loss.
Jluff #35210 05/04/23 11:41 PM
Have your helper slowly turn the pump motor sheave backwards while you swap it out to minimize leakage.
Jluff #35212 05/05/23 03:24 AM
Thats a good trick Montana.
I have had good luck cleaning them before if the screens dirty and car won't level by removing and hitting it with a can of brake clean. Generally works on valve screens for all valves.
Vatorfixer #35216 05/05/23 06:24 PM
I carry a 2 bolt plate for an I-2 and an I-3 valve for quick swapping on belted units too.
Jluff #35218 05/05/23 09:40 PM
Thanks guys.
Do you have part number for the 2 bolt rectangle plate ?
PHP: 8.3.36 Page Time: 0.034s Queries: 31 (0.011s) Memory: 3.0329 MB (Peak: 3.5926 MB) Data Comp: Off Server Time: 2026-11-05 01:21:54 UTC
