Hello, I have 2 TRX5's that are having similar faults. I know what the faults are but I don't know why it's getting them.1 car is getting these:
14 - underspeed
103 - HS stop
8- sb fault
I replaced the sb relays, the aux's on the sh relay, checked my door locks and gate switch. The underspeed will happen anywhere in the shaft way and it can happen if the cars been running nonstop all day or on its first run. It will level off at a floor and then resume it's running. I checked the encoder belts on the gov and the tach on the machine. Physically everything looks good. But I haven't replaced them.
My other car is getting a 413 fault on the dsd 412 drive intermittently and also underspeed once in a while.
Also, the brakes aren't dragging
Sniper
Sniper
list the faults in the order they are and also get the extra info
go error log , select error and enter to get more info
hex value at the bottom of screen
rope slip on sheave
what motor it got pms420 warner brakes
Sniper
Sniper
nore info
There is no extra information. I know what the faults are but I don't know why the underspeed is happening. I'll check the hoist ropes
14 8:26:07
103. 8:26:09
14. 11:14:02
103. 11:14:05
8. 12:49:50
14. 13:21:09
103. 13:21:11
It has an old Westinghouse 208
So yesterday while running it I was getting sn, sh,underspeed and high priority faults. The sh aux's are new, the sb1 sb2 relays are new. I didn't notice and hoist or gov rope slippage.
https://imgur.com/a/VZPRmXZ
Imgur might compress it if you don't have the app. I dunno how else to post that
Here are the faults.
Sniper
Sniper
check shoe lines both car and counterwheight
tacho on governor and car
Maybe gov rope need more tension
Tight spot on the guides
PHP: 8.3.36 Page Time: 0.033s Queries: 28 (0.011s) Memory: 3.0241 MB (Peak: 3.5926 MB) Data Comp: Off Server Time: 2026-11-05 22:18:15 UTC
