0 members (), 98 guests, and 2 robots.
#35326 05/31/23 11:19 PM
I have a Dover Composite blowing the 6A F6 fuse. 9 stop. Car was at 4 with doors fully open. I closed them manually and went to MR. Found F6 blown. Replaced the fuse and turned power back on. Controller came back up and generator kicked on. When I gave it a call, fuse blew again. Fuse is fed from KS on the terminal block and the other side is going to rectifier 2. KS is jumpered to S- on the TB. I ran out fuses but will return in the morning. Any helpful ideas will help. Thanks
I use little circuit breakers to troubleshoot shorts to save on fuses. Sorry I'm not much help on the Dover composites.
Did you find the solution after all?
It's been over a year ago and it's been modded since, but the problem was the carriage solenoid.
PHP: 8.3.36 Page Time: 0.033s Queries: 22 (0.008s) Memory: 3.0102 MB (Peak: 3.5904 MB) Data Comp: Off Server Time: 2026-11-05 18:09:19 UTC
