October
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
10,053 Registered Users
Topics7,404
Posts41,025
Members10,053
#35328 06/01/23 08:58 PM
Going back to a building tomorrow where top access hasn’t worked in a few months, changing boards and key switches.
I work for a small independent company that doesn’t have many Kone accounts. Bottom access works fine, all wiring is the same and can see my door locks make up trying to run up/down. Are there any parameters I can look at to see if something changed? It’s an old elevator where I need to tomahawk the top floor to gain access to the HAS board in the trough but would rather not do that since I’ll be working alone. PM if you have a parameter list. Thanks and work safe!
Check parameter 7-70 (HAS UPPER FLOOR)
Check wiring correct in HAS board
Is the switch itself missing jumper?
Set 7-70 to whatever UI top floor
PHP: 8.3.35 Page Time: 0.036s Queries: 20 (0.008s) Memory: 3.0031 MB (Peak: 3.5922 MB) Data Comp: Off Server Time: 2026-10-11 04:22:03 UTC
