0 members (), 15 guests, and 2 robots.
#35419 06/28/23 10:22 AM
Are there any known issues for connecting IMS to Tac20? Running the newer version IMS and the button to connect is greyed out. Not sure if an older version of IMS would work or if there is another work around.
And I believe the UIT only works the job it was installed in correct? At the very least I am hoping to pull some faults to troubleshoot an issue
What connect button? You have to make a network, group, & car in the control panel, then plug in and wait for it to connect with little red plugs, then you can reload to get light bulbs and then you can open any tools. If you get a com port error when you open IMS you need to set the com port in IMS to the com port you’re using.
The connect button at the top of the control panel which is above the reload button.
I don’t get any red plugs/light bulbs with this and it com port has been verified with what was assigned in device manager
And you’re using blue IMS? Tac20s are slow. In the bottom right corner it’ll say no device connected, then direct connection and bounce back and forth for a minute or 2. As long as it’s doing that, it will connect eventually. If it just says no device connected, something is wrong with your serial adapter, cable, or something. Serial cable should be straight through, no Null Modem. You f you’re on a job with other cars networked together make sure the group number is correct. On a job like that it would be written in the controller door or something if it isn’t group 1.
Yes I’m using the blue IMS. I will have to pay attention to that status next time I’m on site. This is the only car in the building so I should be good on that end.
PHP: 8.3.36 Page Time: 0.026s Queries: 24 (0.008s) Memory: 3.0167 MB (Peak: 3.5927 MB) Data Comp: Off Server Time: 2026-11-05 09:55:26 UTC
