#35640 08/05/23 03:36 PM
BRG
What will cause the relay interface board to sit there and just flash the inputs and outputs?
BRG #35641 08/05/23 04:05 PM
Reseat everything. Check all your power supply connections.
BRG #35650 08/06/23 12:02 PM
Have you tried isolating the card rack by disconnecting the bus wire? Bad inputs and outputs, or a bad card rack can cause it to flash.
BRG #35763 08/19/23 02:05 PM
BRG
Management has let this unit set idle for weeks and the field people haven't listen to what I have asked them to do. I suggested the above things to look at and try, thank you very much, but was met with confrontation and told it has already been done. I'll make this short. I took the ribbon cables loose, blew them and the MSU and replay pilot connectors with compressed air. Three weeks this unit has been down, I spent 15 minutes on it. Unit works and I am looking at retirement after almost 40 years in this business.
BRG #35764 08/19/23 07:00 PM
Well quit looking and go… apprehend it!
Congratulations!
BRG #35765 08/20/23 01:21 AM
Thank you for the update.
PHP: 8.3.33 Page Time: 0.060s Queries: 26 (0.030s) Memory: 3.0199 MB (Peak: 3.5937 MB) Data Comp: Off Server Time: 2026-09-20 21:15:09 UTC
