#35795 08/26/23 11:33 PM
Hello everybody, looking for some help.
Apparently there is a way I've been told that a cube phone number can be reprogrammed. Any info if this is true is appreciated. Thanks.
United #35798 08/27/23 05:30 PM
disconnect the cube and use a regular phone line
United #35799 08/27/23 06:51 PM
BRG Offline
The cube is not one of the best ideas in the world. We have had to reset many of them to get the phone line to work, should work all of the time but not if the cube locks up. Some are marked either "A" or "M" or both. The "M" is a monitoring only device as to where both do the monitoring and phone line. I agree with disconnecting it and going straight to the phone line.
United #35800 08/27/23 06:56 PM
they use mobile app to let in the phone number.
sampler #35801 08/27/23 10:56 PM
We have used the phone line in the past, however, this Schindler lift has no physical phone to programme the emergency phone number. The unit is programmed to dial Schindler. Any other way to change the number? Otherwise we're going to have rehash as we have in the past. The lift is one of the latest 3300 only a year old. Painful.
United #35802 08/28/23 01:24 AM
Does anyone happen to have any schindler papers on this phone, celluar phone box? Programming manual etc?
United #35813 08/30/23 01:09 AM
The phone board should be located in the box on top of the cab. Should be a wurtec keypad, so it can be reprogrammed.
If you don't see it there. Let me know and I'll get better info from one of our constructors.
United #35823 08/30/23 07:08 PM
No phone box located anywhere o n lift unfortunately.
United #36018 09/27/23 07:16 AM
Hi mate,
The cube doesn't work alone, most of the time we install the emergency phone on top of car, under the inspection box or next to it ( 3300 )
The only way to change the phone number will be on the emergency phone, not on the cube.
To access on cube you must use a shindler app, call IoEE - SetupApp.
I highly recommend to install a new phone with physical line or gsm.
Cheers
United #36088 10/06/23 10:47 PM
The phone board isn't in a phone box. Its just the board itself inside a compartment either on the car top, or inside the COP.
If its a 3300, the board is under the lid thats says " no step" on the cartop.
If it is a 5500 or 3300 XL, it will be in the box that has the run station attached most likely.
330s are inside the COP
PHP: 8.3.33 Page Time: 0.039s Queries: 34 (0.023s) Memory: 3.0420 MB (Peak: 3.5922 MB) Data Comp: Off Server Time: 2026-09-20 21:20:41 UTC
