0 registered members (), 19 guests, and 5 spiders.
June
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
8546 Registered Users
Topics6,561
Posts37,103
Members8,546
Most Online117
Jan 16th, 2020
#35915 - 09/13/23 12:14 AM Kone MrRL
beaupeep Offline
beaupeep  Offline
ontario
Having an issue with the guide shoe in the picture falling apart, we’re going to check rail alignment but has anyone else had this issue?
#35921 - 09/13/23 04:45 PM Re: Kone MrRL [Re: beaupeep]
stanklerbin Offline
stanklerbin  Offline
looks like grease on rail
don't use grease
don't use synthetic
#35923 - 09/14/23 01:23 AM Re: Kone MrRL [Re: beaupeep]
EElevator Offline
EElevator  Offline
If it is grease could explain it, grease will get sticky after awhile. Most ecospaces I have have little plastic auto oilers on top of the guide shoe and call for a kone specific rail lube
#35927 - 09/14/23 11:14 PM Re: Kone MrRL [Re: beaupeep]
beaupeep Offline
beaupeep  Offline
ontario
Is there normally a lot of pressure on the guide shoe side to side normally?
#35929 - 09/15/23 03:20 AM Re: Kone MrRL [Re: beaupeep]
omgitsonme Offline
omgitsonme  Offline
Johnson City, TN
Those guides are very common to fall apart. The best thing to use is kone rail lube (konespares part #US53940001) or I prefer to use marvel mystery oil. The biggest thing is to not have grease on the rails/guides since it could speed up deterioration of the slides and could cause the safeties to fail. Also, it's VERY common that the car is twisted rather than the rails being out of alignment. Honestly, I've yet to see a kone unit not twisted. You'll just have to replace the guides every few years
J. Clark
#35933 - 09/15/23 03:50 PM Re: Kone MrRL [Re: beaupeep]
stanklerbin Offline
stanklerbin  Offline
The Kone MRL not only saves MR space but uses motors with small HP that require little power.
That's why they have designed a special command in the LCE to "jog" a car off the safeties (full load testing maybe?) as not much power is available.
Power savings = money savings = selling point long term over hydro's.
Cabs are very light boxes and roped 4:1, 8:1, etc
Like any elevator, empty car down is the most power a machine will ever use/need.
If an empty cab does not move (when the demand is down) for even the slightest moment there will be a mismatch between encoders.
It thinks: one's moving, one's not. You're done.
Grease or dry rails can cause this delayed movement of cab.
As mentioned: Use lube devices designed for the purpose of running up and down the hoistway leaving a light film of oil on rails.
If you have a unit that parks for a long period of time, minimal use environment, it will not oil rails properly.
These elevators are slow.
Guide inserts should not be that big of a deal.
Rotary Oildraulic
Old Otis badge.
Brakes,Coil,Rotor
KONE MX10 repair tool kit
Page Time: 0.037s Queries: 15 (0.010s) Memory: 2.6885 MB (Peak: 2.8593 MB) Zlib disabled. Server Time: 2024-06-16 04:08:27 UTC
