0 registered members (), 17 guests, and 3 spiders.
June
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
8546 Registered Users
Topics6,561
Posts37,103
Members8,546
Most Online117
Jan 16th, 2020
#35954 - 09/19/23 09:54 PM Kone 120 fault sub fault 1025
beaupeep Offline
beaupeep  Offline
ontario
Anyone ever have this? Don’t have this one in my list.
#35955 - 09/19/23 10:15 PM Re: Kone 120 fault sub fault 1025 [Re: beaupeep]
Indirtwetrust Offline
Local 18
It’s drive specific, what drive do you have
#35956 - 09/19/23 10:16 PM Re: Kone 120 fault sub fault 1025 [Re: Indirtwetrust]
beaupeep Offline
beaupeep  Offline
ontario
Kdl16 I believe
#35957 - 09/19/23 10:20 PM Re: Kone 120 fault sub fault 1025 [Re: beaupeep]
Fehlerteufel Online content
Fehlerteufel  Online Content
120 1025 Motor Current No Motor current or one phase current missing
0 0 Problem in motor wiring or motor. Drive is faulted. Start is prevented until
problem is fixed.
#35983 - 09/21/23 01:37 AM Re: Kone 120 fault sub fault 1025 [Re: beaupeep]
EElevator Offline
EElevator  Offline
I had this once, same fault subcode and drive. I tried everything I could. Megged the motor numerous times, went over motor wires, redid connections, pulled drive and sent it to Access. There was more im sure, going just off memory here. Ended up explaining to the customer that the drive needed replaced, or they could risk just replacing the board in the drive with the current transformers on it (CO16 board If I remember correctly) but there was a chance the drive could still need replaced.
Once I'd determined the issue was in the drive I quit investing time troubleshooting when calls came in and just took notes and reset it, usually once a week. This went on for awhile because the customer didn't want to spend money and my company gives work away for free and wasn't billing for these callbacks. Eventually they did push billing the customer and the customer had another company quietly come in and replaced the CO16 board I think because all of a sudden it just magically was fixed and never broke again, but the drive still had my handwriting on the side so it wasn't an entire new drive.
Side note, if you have a drive that has blown IGBTs or something simple send it to access and have it rebuilt. If it's a control side issue or intermittent problem, don't send it. Just replace it.
#35988 - 09/21/23 06:58 PM Re: Kone 120 fault sub fault 1025 [Re: EElevator]
beaupeep Offline
beaupeep  Offline
ontario
Ok, got lift to move on inspection but won’t run on auto due to 0244 fault and 2716 fault believe they are monitoring of governor tension sheave and traction loss detection means. Tried replacing option board 722:F but have same issue. Am i looking in the wrong place?
#35990 - 09/21/23 07:57 PM Re: Kone 120 fault sub fault 1025 [Re: beaupeep]
maybe this will help.
#35991 - 09/21/23 08:14 PM Re: Kone 120 fault sub fault 1025 [Re: Fehlerteufel]
beaupeep Offline
beaupeep  Offline
ontario
So if my jumper isn’t on either front or rear, it could be a problem?
#35992 - 09/21/23 09:28 PM Re: Kone 120 fault sub fault 1025 [Re: beaupeep]
yes, that is a problem.
see the circuit diagram.
Rotary Oildraulic
Old Otis badge.
Brakes,Coil,Rotor
KONE MX10 repair tool kit
Page Time: 0.034s Queries: 16 (0.010s) Memory: 2.7138 MB (Peak: 2.9119 MB) Zlib disabled. Server Time: 2024-06-16 06:50:15 UTC
