#36054 10/04/23 02:09 AM
Have a bad PA door board & Vertical Express wants to replace it with an LD16 Operator as they no longer make or stock the PA door boards. Anybody got any experience with this? Any issues?
wltr00 #36056 10/04/23 05:23 AM
PA? Sorry not familiar with that abbreviation. Got a part number or picture?
wltr00 #36065 10/04/23 10:58 AM
6300PA6 door board. They’ve used it for years but obsolete now
wltr00 #36072 10/05/23 01:21 AM
Yes! have the same dilemma currently on a TAC20 (6300PA3). TK still makes the boards but there is a world-wide chip storage, so any boards they do have they are not selling to outsiders. you can try to get board repaired but the success rate is only 50-60%. i think the LD-16 drive kit upgrade is the way to go here depending on controller. at least you can buy parts from Wittur or Kone..
wltr00 #36075 10/05/23 05:09 PM
Keep in mind that you’ll still have to get the 2 boards from TK. The CAN interface board and the main board because it has firmware in it you can’t get from Wittur to be code compliant.
Going to an MOVFR or MOVFE isn’t a bad option if you have an open discrete port and at least 6 spare travel cable wires.
wltr00 #36090 10/06/23 11:53 PM
Here is the chart for door boards , Vertical Express sent this
wltr00 #36093 10/08/23 12:01 AM
JJR Offline
I think the LD-16 (Wittur product is your best bet as they are engineered specifically as direct replacements for the old Miami Elevator/Early TK door equipment. I'm also a grinch of harmonic operators. They are just too outdated and have too many moving parts. If you wanna go cheaper, GAL has a direct replacement linear product where the only thing you'll need to replace is the operator itself. You will be able to reuse other existing components, such as the skate and hanger roller/tracks. It's called OMNI. Just like LD-16, there's no limit cams/switches to deal with. If you've been having difficulties getting parts from VE/TKE, the GAL product is your best bet. It might be easier to source parts.
LInk: https://www.gal.com/wp-content/uploads/2023/08/GAL-MONXT-OMNI-Telescopic-Linear-Operator.pdf
You could also get a Glide-A (or P) from Otis.
PHP: 8.3.33 Page Time: 0.020s Queries: 29 (0.005s) Memory: 3.0284 MB (Peak: 3.5925 MB) Data Comp: Off Server Time: 2026-09-21 14:15:36 UTC
