1 members (JB01),
Posts: 13 |
Have a tac 20 2 stop . Car keeps shutting down after one trip and then we must reset main line to reset, again, and again. Muts relay is bussing changed to no avail.
Posts: 120 |
Have you replaced your tape guides, and check your prox sensors. Make sure you haven't bent any pins on the plug on the tape reader board. Also check your switchs in the top of the hoistway. Or get a ims computer it will tell you whats wrong. Good luck.
elevator lifer
elevator lifer
Posts: 179 |
Can't do much without the IMS
Posts: 5 |
Check your magnets havn't moved, specifically the paraty mag.
elevator lifer
elevator lifer
Posts: 179 |
I have replace the selector boards on about 75% of the jobs I have. They seem to be a weak point on these systems.
elevator lifer
elevator lifer
Posts: 179 |
but once again IMS will tell you quick whats up are you local to md or nj or pa?
Posts: 64 |
replace the relays throughout the MCD and MCE circuits, the original relays suck. common problem with a Tac20.
Posts: 94 |
I agree replace the relays....garbage! You can also try taking the relays out and hitting them on a hard surface, i was told this will "reset the coil" it works sometime and will get you out of a jam until you can get new relays.
Posts: 280 |
anytime otis takes on a tac20 we install a reliability kit which includes all new relays
Posts: 52 |
whats in a reliability kit?
Posts: 366 |
A new elevator
Posts: 64 |
E311>>><<< you know better, the tac 20 is one hell of a fine elevator system if you have the tools to work on them. they sure dispatch faster than any 211.
gs264>>><<< the big O calls them a first aid kit which contains silver tipped relays, both the 24v and the 110v to replace the originals which sucked right out of the box. it also contains new back-up batteries and some floppy disks to download the software on.
Posts: 94 |
Don't know if this has anything to do with your issue but i am putting this out there because when i did work at TKE we ran across this on the TAC20 and the TAC50's....check all your connections that are factory installed, we had an issue in are area were the wire was behind the screw termainal! didn't start having problems untill almost a year after install. found this on power supplies and "aux" relays to the starter.
Posts: 366 |
I know, I know....the Tac 20 is a fine unit. If I didnt have an LVM I would take the Tac 20 next
Posts: 64 |
billvator>>><<< you do that on any unit, make or model... don't you?
Posts: 94 |
Yes ifrratedpilot but it is a good lesson to remember. This job was not mine and i got to figure it out at 2 a.m. on a hospital hela-pad trama elevator. The Tac 20 is a good unit, but i would still take a DMC.
Posts: 419 |
Reminds me of my 1st CB base.
We had the job for 3 days. I get a night call on Friday, that an elevator was down and had to be running. I get there, and there's nothing in the machine room but a book. Called my Boss, and asked does anybody know about this stuff? He told me that I would know all about it after I fixed it..LOL...
Sat in the machine room for the next 6 hours on time and 1/2, read the book, then fixed it in about an hour..
Posts: 194 |
you just have to love those lon board communiction setup..such a great engineering marvel..great callback in the middle of the nite all hallbuttons lite up and you have to find which floor is giving you problems....yes I,ll take 20 211 over 1 tac20
Posts: 220 |
They are a pain. Every time I have to get involved with one it is some kind of Lon problem. The book I have is fine if you keep in mind that it assumes that you work for Thyssen and can get factory replacement boards. I usually have to work backwards to figure out what generic files I am missing. One tip is to look for any floor that may have got wet. The Rj45 connectors that daisy chain fixture to fixture corrode easily.
Posts: 64 |
i do not work for TKE and have never had a problem repairing at Tac 20 whether it be a LON problem or whatever. Schindler uses LON on their 321's and 330's.
