0 members (), 14 guests, and 2 robots.
Page 1 of 3 1 2 3
#3572 05/17/12 12:52 PM
Have a tac 20 2 stop . Car keeps shutting down after one trip and then we must reset main line to reset, again, and again. Muts relay is bussing changed to no avail.
scottsr #3573 05/17/12 03:37 PM
Have you replaced your tape guides, and check your prox sensors. Make sure you haven't bent any pins on the plug on the tape reader board. Also check your switchs in the top of the hoistway. Or get a ims computer it will tell you whats wrong. Good luck.
Take the stairs #3575 05/17/12 05:39 PM
elevator lifer
elevator lifer
Can't do much without the IMS
aquadag #3581 05/18/12 01:37 AM
Check your magnets havn't moved, specifically the paraty mag.
Engine31 #3583 05/18/12 01:51 AM
elevator lifer
elevator lifer
I have replace the selector boards on about 75% of the jobs I have. They seem to be a weak point on these systems.
aquadag #3584 05/18/12 01:52 AM
elevator lifer
elevator lifer
but once again IMS will tell you quick whats up are you local to md or nj or pa?
aquadag #3591 05/18/12 08:18 AM
replace the relays throughout the MCD and MCE circuits, the original relays suck. common problem with a Tac20.
ifrratedpilot #3592 05/18/12 01:50 PM
I agree replace the relays....garbage! You can also try taking the relays out and hitting them on a hard surface, i was told this will "reset the coil" it works sometime and will get you out of a jam until you can get new relays.
billvator #3607 05/19/12 04:02 AM
anytime otis takes on a tac20 we install a reliability kit which includes all new relays
GreenPants #3638 05/22/12 02:39 AM
whats in a reliability kit?
gs264 #3643 05/22/12 07:27 PM
A new elevator laugh
E311 #3645 05/22/12 08:21 PM
E311>>><<< you know better, the tac 20 is one hell of a fine elevator system if you have the tools to work on them. they sure dispatch faster than any 211.
gs264>>><<< the big O calls them a first aid kit which contains silver tipped relays, both the 24v and the 110v to replace the originals which sucked right out of the box. it also contains new back-up batteries and some floppy disks to download the software on.
ifrratedpilot #3648 05/22/12 09:52 PM
Don't know if this has anything to do with your issue but i am putting this out there because when i did work at TKE we ran across this on the TAC20 and the TAC50's....check all your connections that are factory installed, we had an issue in are area were the wire was behind the screw termainal! didn't start having problems untill almost a year after install. found this on power supplies and "aux" relays to the starter.
billvator #3649 05/22/12 10:50 PM
I know, I know....the Tac 20 is a fine unit. If I didnt have an LVM I would take the Tac 20 next smile
E311 #3650 05/22/12 11:05 PM
billvator>>><<< you do that on any unit, make or model... don't you?
ifrratedpilot #3651 05/23/12 02:03 AM
Yes ifrratedpilot but it is a good lesson to remember. This job was not mine and i got to figure it out at 2 a.m. on a hospital hela-pad trama elevator. The Tac 20 is a good unit, but i would still take a DMC.
billvator #3653 05/23/12 02:40 PM
Reminds me of my 1st CB base.
We had the job for 3 days. I get a night call on Friday, that an elevator was down and had to be running. I get there, and there's nothing in the machine room but a book. Called my Boss, and asked does anybody know about this stuff? He told me that I would know all about it after I fixed it..LOL...
Sat in the machine room for the next 6 hours on time and 1/2, read the book, then fixed it in about an hour..
Broke_Sheave #3656 05/24/12 01:25 AM
Len Offline
you just have to love those lon board communiction setup..such a great engineering marvel..great callback in the middle of the nite all hallbuttons lite up and you have to find which floor is giving you problems....yes I,ll take 20 211 over 1 tac20
Len #3686 05/25/12 11:37 PM
They are a pain. Every time I have to get involved with one it is some kind of Lon problem. The book I have is fine if you keep in mind that it assumes that you work for Thyssen and can get factory replacement boards. I usually have to work backwards to figure out what generic files I am missing. One tip is to look for any floor that may have got wet. The Rj45 connectors that daisy chain fixture to fixture corrode easily.
Smitty #3691 05/26/12 12:32 PM
i do not work for TKE and have never had a problem repairing at Tac 20 whether it be a LON problem or whatever. Schindler uses LON on their 321's and 330's.
Page 1 of 3 1 2 3
PHP: 8.3.36 Page Time: 0.059s Queries: 54 (0.021s) Memory: 3.1180 MB (Peak: 3.5927 MB) Data Comp: Off Server Time: 2026-11-05 13:02:00 UTC
