0 registered members (), 17 guests, and 3 spiders.
June
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
8546 Registered Users
Topics6,561
Posts37,103
Members8,546
Most Online117
Jan 16th, 2020
#36432 - 12/19/23 10:33 PM MAC door operator with 104 board
beaupeep Offline
beaupeep  Offline
ontario
Can anyone explain why there is a high performance and standard jumper on this door board? When i have it on high performance the door stalls 2/3’s of the way in the open position only but on standard the door opens no problem.
#36433 - 12/19/23 10:58 PM Re: MAC door operator with 104 board [Re: beaupeep]
john jay Offline
john jay  Offline
ohio
As I understood it, high performance was used when there were heavy hoistway doors. If your operator is a high-performance operator, the belt and sheave configuration will look different than the standard MAC operator. Also if you have a high-performance operator you will have 2 wired pairs on terminal TB3. If you only have one pair of wires at TB3 you have a standard MAC operator and it was adjusted accordingly.
#36441 - 12/20/23 09:43 PM Re: MAC door operator with 104 board [Re: john jay]
beaupeep Offline
beaupeep  Offline
ontario
Definitely have 4 wires going into TB3, so should be set to high performance, but not strong enough to open the doors all the way, standard works though.
#36443 - 12/20/23 10:36 PM Re: MAC door operator with 104 board [Re: beaupeep]
john jay Offline
john jay  Offline
ohio
If you want to mess with it try turning up the OF pot. Also, you can remove the J3 jumper and see if there is better operation. These operators have an internal timer that will stop the motor if the doors do not get fully open in 15 seconds. That said when I was a green mechanic I was told by a foreman on the job, if it ain't broke, don't fix it.
#36447 - 12/21/23 02:52 AM Re: MAC door operator with 104 board [Re: john jay]
beaupeep Offline
beaupeep  Offline
ontario
Tried the of but only had a little response but when i switched it over to standard and tried opening the doors i thought they were going to fly off the track they were moving so fast.
Rotary Oildraulic
Old Otis badge.
Brakes,Coil,Rotor
KONE MX10 repair tool kit
Page Time: 0.035s Queries: 15 (0.010s) Memory: 2.6807 MB (Peak: 2.8400 MB) Zlib disabled. Server Time: 2024-06-16 06:11:54 UTC
