Posts40,940
#3606 05/19/12 02:23 AM
i am working on a v3f16 drive and i found that the igbt transistor as been burnt out on the same spot when i opened it,have anyone replace the transistor on these drive and it work?and what cause the transistor to be burnt out
Could be loose motor leads...@motor jb or remote jb etc. Dragging brakes or unbalanced cwt. Or tight or unlubricated rails. Most likely cause...shavings sucked into motor when top motor to rail connection was drilled in place without covering motor.
Thanks steve,i guess this as a lot to do with maintenance
Not necessarily the case...multiple drive failures could be due to a number of possible issues...like 1)incoming power issues 2)poor installation 3)maintenance...it can't be nailed on any 1 of these without evidence on the contrary...
Or just that these drives are crap. I'm replacing another one tomorrow, the second one this month. 0103 and a 0026 fault is a sure sign of another one biting the dust. Although I must say the replacement drives are lasting a lot longer but $5300 is too much. And they say their equipment is not proprietory! Kone makes up for losing cars on service by charging outragous prices for parts.
$5300 from Kone Sparees!? That's a steal for those piles of garbage.
galaxy #3737 05/31/12 02:28 PM
Definitely open the drive up and check the connections inside...seen several with just loose connections inside. Also have you tried just having it repaired? http://www.elevatorcircuitboards.com/drives.html
Already checked all connections inside the drive. We gave the customer an option of new or rebuilt, but in my experience the rebuilts don't last as long. I think Kone upped the quality of the new replacement drives. Thanks for the suggestions
Order the larger 25amp version from spares...its well worth the extra cost. G14 at end of part # instead of G13.
Can u tell me what fault 01 08 is please on the
Same drive , I have a problem with down levelling,
Simon #4998 10/26/12 03:12 PM
Check your load weigher
jwrw #5058 11/01/12 05:34 PM
O
O Offline
i have a problem with v3f16l with 120 fault code and sub code 2025 the contactors are energizatet , but the car dosent move can u tell me please what is the problem
JC3 Offline
Spoken to few KONE testers and technical personnel in South East Asia. KONE V3F16L drive typically have short life span ranging from 1 to 4 years. But the average is less than 2 years. The common error codes are 0026 (Drive Fault) and 0103 (Brake Resistor). Drive Ready LED on MAP panel would not go on.
Once stripped of its housing, by physical inspection, there is no damages. Components & PCB appear to be in good shape.
There were cases where tester began to commission the lift, the drive went K.O. and delayed the lift hand-over to client.
I am suspecting KONE is being unethical in charging drive replacement at exorbitant price. They sell Monospace really cheap but recovers profit from spare parts, where the main income comes from drives replacement.
A lot of monospace customers are pissed off with KONE.
Can anyone identify problem at V3F16L? Is there anything can be done? If there is runtime limiter in the software, then ... there is nothing we could do.
Kindly share your experiences.
JC3 #5106 11/07/12 04:14 AM
If you ever need to replace a v3f16 drive order the new KDL16 drive instead.. Not sure how much more of a cost but much better drive and also you add a resolver with it so no more irratic operation on inspection knowing the magnetic north.
Does anybody know how to fix the v3f16l?
I have errors 0026 and 0103.
Which parts are usually burnt?
JC3 Offline
replaced V3F16 with KDL16.
It works fine. Noted new one comes with PG instead of tacho.
Has anybody tried replacing KONE controller with another controller? use commercial drives such as Yaskawa?
Any idea?
JC3 #5631 01/25/13 09:45 AM
JC3 Offline
Met another angry (and rich) customer, who is about to dump KONE monospace lift onto the road and have journalist to make headlines.
Apparently V3F18 also have problems, probably to do with IGBT / main circuit driving board.
On the other hand, KONE testers lacking training have no idea how to troubleshoot and solve the problems. Poor installation aggravates the matter. :-(
PHP: 8.3.33 Page Time: 0.027s Queries: 48 (0.008s) Memory: 3.0805 MB (Peak: 3.5941 MB) Data Comp: Off Server Time: 2026-09-21 07:37:29 UTC
