0 members (), 24 guests, and 1 robot.
#36553 01/10/24 11:44 PM
I have a Montgomery MG set installed a rebuilt hoist motor car first would run on inspection. Car no longer will run. I checked armature voltage and I’m only getting 35-45 vdc off generator motor is rated for 200v . When I read resistance on my fields I’m getting 15ohms shop said they should be 87ohms any ideas in which direction I should go from here? This is an old Montgomery where they use a shunt motor in damping circuit. I believe car is late 60 early 70s
Something to check. Does The relay AR energize? It is a relay that is pulled in with amps, not volts. It is in the armature loop circuit. This is all way back memory so like I said, just something to look at.
Another thought just occurred. I believe that the small shunt motor is what pulls AR relay in. The car will not go into high speed without AR. I think as the shunt spins it pulls in AR.
john jay #36557 01/11/24 03:43 AM
Thank you John jay. Tomorrow I’ll get back to you after having more time trying a few things . I believe your correct its something to do with this shunt motor not feeding circuit correctly .
PHP: 8.3.33 Page Time: 0.022s Queries: 22 (0.006s) Memory: 3.0113 MB (Peak: 3.5923 MB) Data Comp: Off Server Time: 2026-09-21 18:35:49 UTC
