#36649 01/24/24 03:53 AM
Is it possible to relearn buttons? I currently have a door open, door close and door hold all working as a door open. I’d like to relearn/ reprogram door close and door hold.
MX4 Offline
TouchOfTheTism’
TouchOfTheTism’
You can but you need F2K config to do it
You need "F2K Config" + KM50300810G01 (https://partsview.konespares.com/Details?id=73727) or special "Key Switch" https://parts.kone.com/Products/KM804250G10.
How does it work?
Pm me your email.
I assume it is KONE European type that has F2KMUL. the Chinese one has COB that you easily change the plug connected.
Also you can replace it with Chinese type too. Very cheap.
You can re do most cop with that key switch. But you'll Also need the write up with it. As for the f2k tool if you don't have someone to show you how to use it you'll be lost. Pm me and I can give you the doc number for the key switch
It works with the software program F2K. It is the interface to the Mul board. You can pretty quickly reconfigure buttons much easier than the arcane method using the key switch. Actually some guys power up a spare MUL board with a couple batteries and can set these things up on a desk before taking them to the field.
PHP: 8.3.36 Page Time: 0.168s Queries: 30 (0.083s) Memory: 3.0299 MB (Peak: 3.5904 MB) Data Comp: Off Server Time: 2026-11-04 21:28:16 UTC
