Page 1 of 2 1 2
#36666 01/26/24 07:06 PM
Good Afternoon,
I'll try not to make this too long, but received a call yesterday on a KONE Mono KCM. Of course, it's one of the critical cars in the Hospital, nonetheless, when I arrived, the car would not
1. Take a demand or hall call
2. Respond to Inspection or any Automatic call from the controller
3. E-Brake will pick but the car will not run in either direction.
Navigating through KONE's oh-so-friendly prints, it's leading me back to this Boost Brake Module for the Main Brake. Mind you, when given a direction via inspection, the car will not move. I don't have "Main Brake to CH1 or Main Brake to CH2" high. When I plug in XB1 (sorry if my terminals or name is incorrect, my head is spinning right now) into the E-Brake Module, "Main Brake to CH1 and Main Brake to CH2" go high or lite. It won't run under that condition, but can I assume that we have a bad boost brake board?
All other voltage checks, seem to check out. Even the output from the Main Brake Module of 480 and E-Brake 230. Very confusing, but what else could it be? Again, upon a direction, it will pick the E-brake and then fault out the drive w/o a direction (direction being movement). In addition, the ADON board is not faulting out, so again, I can't see any inputs shorted that may cause anything back to the ADON and/or CPU.
Any help is appreciated, thanks a bunch!
What error does the fault log throw?
john_jay
I thought I wrote it down yesterday, but I want to say it was a 186 or 188, besides the 0021.
john_jay
188!
If it doesn't move with E-Break Handel when the power is off, you got Mechanical Issue.
KONE LCE has sub code error, so when you see the error code like F 0186 push the select button it shows you the Sub code error.
Also, what is your inverter type? (V3F25, KDL32, KDM, ...)
Hey
Yes it moves via the brake release. As for the drive, it's a KDM. I'll send over the sub-codes Monday morning. I had everything written down and had to take other calls around the complex and left behind.
Odd with the outputs voltage being there, why it would fault out. Makes me wonder without doving to deep I to the prints, if this drive didnt take a sh.. Before I go there, I'll do some digging Monday
The best way for this kind of trouble shooting is take a video from it. including fault reading and LED check.
If this is a MRL, you are prob going to have to drift the car up with the emergency release so you can access the brake. The 188 is telling you that one of the brakes is not opening. You can also switch the input voltage from the E-Brake to the main Brake. to see if it is a board prob or a brake issue.
I was thinking about swapping XB1 from Main Brake Module over to the E-Brake module. I'll give that a try.
Yeah it's a MX32 Mono, so I can assess both brakes in the machine room.
Funny they just changed both modules in 2020, again odd things go bad that quick. Call me old I guess, just seems as though there's another problem deeper, but changing out both works for some I guess.
Kone Mono Space = Machin Room Less (MRL)
Kone Mini Space = With Machin Room
Looking forward to see the sub code and some picture
Replace ADON board. If you have a ADON 3 do it
There 3500 I know not cheap. If you have a kone friend. Swap for parts
If you need any KONE parts give me a KM number, I will find a good price for it.
Ok finally back...so I swappednthe modules hoping one (main) was bad not allowing the main brake to pick. To no avail, after swapping, same issue or problem.
Either on insp or auto, e-brake picks but not the main.
I have a video not knowing if will do much help and a picture of the brake. Video may be too large, but I can send via PM or text
As for the sub-codes...I'm getting 0026 2103 and same for if on inspection 0021 2103.
So that is telling you that the Brake Modules are good and the problem is either a bad wire to the Brake Module or a bad Adon2 Bd, or the board that goes out to the Brake. You should be able to check the wire and eliminate or confirm that, and go from there. If you have a meter and a print you should be able to pin it down.
Sometimes there's no better troubleshooting tool than a second identical car that's running properly. If you swapped the brake modules and it didn't move, swap another part. I'd swap adon boards next.
By "it" moving l meant the problem
I just see two pictures and no video.
the F 0026 usually appear with other Drive faults (0100~0150) Sub Code of those faults are important and you can refer to Fault code of each Drive.
the number of faults appear first like shows "F 2" then shows " 0026" that means you have 2 error and fist one is 0026 for second one you should press up or down button on CPU.
That is why I said video will help because show these and also LEDs on CPU.
Changing Parts with working elevator she best way to test which part is defective, but also may cause problem in working elevator too.
So just consider that.
For problem like these we always check the Break Controller.
Wait, I just re-read your last post. If you switch brake input wires, at the brake, and you get the same problem, that means your main brake is getting voltage and not opening. Is this correct? You can easily test this with a meter. If so the brake is either out of adjustment, or the brake module is bad. with everything handy right in the MR you should not have a problem figuring this out.
Page 1 of 2 1 2
PHP: 8.3.33 Page Time: 0.028s Queries: 56 (0.010s) Memory: 3.1159 MB (Peak: 3.5923 MB) Data Comp: Off Server Time: 2026-09-20 22:04:51 UTC
