#36713 01/30/24 03:49 AM
Got a car that faults out about once every 10 days. 94 fault xtra info 0000 0010 CDOOR contact was active with doors fully open. Gate switch not hanging up and it's a GAL style so the roller would kick it out if it was. Wiring to the CIO board looks good, no shorts. Replaced the door close limit reed switch just in case, door open limit is virtual off the LUST door drive. No issues with the operation of the door while onsite testing. Had an event where the SKD4 LED was flickering however SKD5 LED did not even though it'ss in series with SKD4. Car is a duplex, thinking about swapping the CRIPHNA board with the other car next time it goes down to see if I can move the problem before I throw more parts at it.
Anyone have this fault with the same xtra info and have a resolution?
Either replace the CRIPHNA board or have it sent off and the cdoor and sdoor relays replaced (and the auxiliary ones, I think cdoor20 and sdoor 20). Those relays are failing and unfortunately schindler soldered them into the board
If it was me and I was sending the board out, I'd have all the relays on it replaced. And scratch marks in them before sending the board out so you know they were replaced
Just went down this road not too long ago, ended up being the optocoupler on the crip board. This was a 321 tho but same fault.
MX4 Offline
TouchOfTheTism’
TouchOfTheTism’
If your boss pays the extra money I believe Access will add sockets so you can just change the relays next time, a bit pricey from what I understand.
Got the CRIPHNA board back from repair a few weeks ago and it has solved the problem thus far. Thanks for the info guys.
Thanks for the follow up
Glad you got it
PHP: 8.3.36 Page Time: 0.038s Queries: 30 (0.007s) Memory: 3.0316 MB (Peak: 3.5926 MB) Data Comp: Off Server Time: 2026-11-05 07:55:41 UTC
