0 registered members (), 17 guests, and 0 spiders.
June
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
8546 Registered Users
Topics6,549
Posts37,013
Members8,546
Most Online117
Jan 16th, 2020
#36964 - 02/28/24 08:22 PM TAC20-03 SW Issue
wltr00 Online content
wltr00  Online Content
Trying to upload the job file and following the instructions in the TAC20 manual, got to Service>Transfers. The EEPROM window opens but I cannot select the file to be uploaded to the TAC20-03. I cannot locate the file to upload even though when not connected to the TAC20 I can see the job name and folder in C> Program Files>Thyssen>IMS>Jobs. Any ideas on what I'm doing wrong?
#36970 - 02/29/24 09:50 PM Re: TAC20-03 SW Issue [Re: wltr00]
Indirtwetrust Offline
Local 18
When you’re browsing for the file in Windows Explorer change the file type to all files
#36972 - 03/01/24 01:36 AM Re: TAC20-03 SW Issue [Re: wltr00]
It doesn’t let you select all files. See attached photo. Drop down window has no other selections except the one shown.
#36974 - 03/02/24 01:13 AM Re: TAC20-03 SW Issue [Re: wltr00]
Local 18
So you can’t even see the job named folder? I’m not sure what’s going on there but I don’t think I’ve ever tried to load a job file like that before. Probably best to just rename it _07c000.dat and load it through Hyperterminal. And when you do that it’s a good idea to make another copy of the file named _0f8000.dat and load both at the same time.
#36976 - 03/02/24 02:19 PM Re: TAC20-03 SW Issue [Re: wltr00]
No can’t even see the job named folder but it’s there. So 2 copies of the original downloaded job file and just rename the same file twice to 07 & Of?
#36977 - 03/02/24 02:26 PM Re: TAC20-03 SW Issue [Re: wltr00]
EElevator Offline
EElevator  Offline
I'm not sure, but I was told by someone much smarter than me on tac 20s that you can't load the car files through ims like that. That it has to be done through hyperterminal. I think it's also best to change the file name on the hyperterminal to .Dat to upload all 5 files at once. Wouldn't hurt.
#36978 - 03/02/24 04:30 PM Re: TAC20-03 SW Issue [Re: wltr00]
Local 18
Ya, I always load the 2 copies of the job file and the 3 generic software files at the same time. Put all 5 in the same folder, select one in Hyperterminal then delete the entire file name and replace with an * leaving the .dat so it reads: folder/*.dat then send
Rotary Oildraulic
Old Otis badge.
Brakes,Coil,Rotor
KONE MX10 repair tool kit
Page Time: 0.029s Queries: 16 (0.008s) Memory: 2.6983 MB (Peak: 2.8786 MB) Zlib disabled. Server Time: 2024-06-01 22:16:18 UTC
