#37066 03/15/24 02:46 AM
Kiwi
Kiwi
How do I set up the 3D operation of the G3510 detectors with the G3851 Memco Panachrome Universal Controller.
I have checked that the door detectors on the correct doors (TX on the left looking from the landing) and (RX on the right)
I have the manual and have been trying to use the 3D (Smart 3D set up, but cant get the 3D to work
Can some one help. Thanks.
crustyone #37070 03/15/24 07:16 AM
Does 2D detection work?
Is the alignment of the light curtain correct (height, depth, parallel, in a line)?
What type of landing door/cage door is installed?
Car doors with a rigid door cam have a negative offset when opening from the closing edge of the car door to the landing door, which means that 3D detection does not work reliably or at all.
Is the earthing cable connected?
Light curtain type set correctly G3510?
3D function activated?
What does the display status show?
crustyone #37071 03/15/24 07:42 AM
Kiwi
Kiwi
The car and landing doors are single panel center opening.
The detectors are correctly installed and aligned.
The 2D works perfectly.
I will check on site re the offset between the car and landing door front edge and get back to you.
I am not sure that I am following the correct set up in the Memco manual.
crustyone #38573 11/23/24 03:44 PM
Crusty,
Did you figure this out? We are having the same problem with our Panachrome Smart 3D install.
PHP: 8.3.36 Page Time: 0.028s Queries: 23 (0.011s) Memory: 3.0141 MB (Peak: 3.5927 MB) Data Comp: Off Server Time: 2026-11-06 06:04:40 UTC
