0 members (), 74 guests, and 2 robots.
October
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
10,053 Registered Users
Topics7,404
Posts41,025
Members10,053
I have a couple questions here. Had an older 561 CPU fail so got a new one with 9.5.9 software and an ADON3. Put in all parameters and did an ADON learn but couldn’t get a shaft setup because have no car comm and no 71S from the CCBN. I did a 5-7-1 and it took over 1-1/2 hours. Has anyone ever seen this before? Starts at 01000 with the last 0 flashing then super slowly counts up by 1000 until finally got to 39000 and completed. Still have no car comm and I’m told I need a new CCBN to be compatible. I have to keep this service car running though so put the old CPU and ADON back in and did a 5-7-1. It’s going about half the speed as the first time. Should this even work going back after doing the 5-7-1 with the newer software? I’m sure this is going to take 3 hours this time. Is something wrong? I know Kone guys never do 5-7-2s but our tech support wanted me to do a 5-7-2 then 2 x 5-7-1s before saying for sure I need the new CCBN but that’ll take like 5 hours.
MX4 Offline
I PM’d you.
That shouldn't take such a time unless one or more component has issue.
Starting from CCBN is a good idea.
Also, remember you can change NVRam of CPU with old one. In that case all your parameter and Lon download will revile.
Not to the new model CPU. I figured it out this morning though, I had swapped XM13 and XH12 plugs when installing the CPU.
PHP: 8.3.35 Page Time: 0.040s Queries: 22 (0.007s) Memory: 3.0120 MB (Peak: 3.5923 MB) Data Comp: Off Server Time: 2026-10-11 02:02:41 UTC
