Page 2 of 2 1 2
Sucks you all are having so much problems with smartrise, installed a ton and never had issues even on there tractions
What about Alpha? Engineers from smartrise started that one
DMC are the Best Hydros from dover and 211 from Otis are bullet proof, I have about 60 DMC on my route,
V Offline
The CLC red light needs to be on. Chances are if it’s an old power supply that you have a bad power supply. Even though your meter shows 5.09 vdc dosnt mean it’s clean power. Check the voltage with your mete on AC. If you have more than 1 vac on the power supply it’s junk. With the CLC board with only LCC 11 plugged in you should have the light on! If not bad power or bad board! I’ve seen new boards be bad out of the box.
Page 2 of 2 1 2
PHP: 8.3.33 Page Time: 0.017s Queries: 19 (0.005s) Memory: 3.0191 MB (Peak: 3.5925 MB) Data Comp: Off Server Time: 2026-09-20 20:24:53 UTC
