Page 1 of 2 1 2
#37404 05/06/24 06:53 PM
I’m looking for suggestions here on an OTIS Gen 2. I’m working on car 1 in a 2 car group. Its current status is NAV. All batteries have been replaced other than the small 3v one. I know batteries have caused me weird issues in the past. My status is NAV unless I put it on INS. It runs fine on Inspect and will also take calls via the blue tool. I’ve performed multiple successful learn trips. I’ve also went through pretty much every parameter setting and compared them to the other identical car in the group. Nothing is different other than car specific parameters.
Here is what I’m hoping may clue some of you in on the problem…
Under 1-3-1-2 (RISE)
My bottom “old” setting is stuck on 065. It should be at 001. It won’t let me change it. Yes, I turned off write protect.
Also under 1-3-1-5 (RAND-C) stuck on 255. It will not change back to 000. I changed this in an attempt to let it run with random car calls to make sure it was fixed before putting it back to normal operation.
Any advice would help at this point. Thanks!
Whats your shutdown log say? Error log?
MX4 Offline
M1221
M222
M421
What does these say?
The original fault was a drive fault. It referenced a phase imbalance of some sort. I checked phasing and power and sure enough I had low voltage coming out of the drive. I turned off power and basically did a drive PM. Checked and tightened all connections, terminals, etc… Put the power back to it and all checked out fine… I assumed I had a loose connection or there was power issue in the building that is now resolved. In my attempt to make sure there wasn’t more to the problem I wanted to let it run on random car calls for a while before putting back into public service. Thats when I followed the manual to turn off doors and put the car on random car calls for a while. It never worked after that… To answer your question it is currently logging and 1800 EFO-Mismatch fault and an 1801 ASL-P mismatch fault. At that point I put the elevator back into service from a parameter perspective. Doors back on etc. At this point RAND-C will not allow me to change back to 000 through
1-3-5-1 and now my bottom floor setting is stuck on 065. I never changed anything on the bottom floor setting in 1-3-1-2, so I don’t know how that changed to 065. Per the manual it can only go to 064. It stays that way even after multiple successful learn trips.
It’s screwed up. I haven’t forgot that the drive may still be an issue. However it will take calls and run fine when I give it commands from the tool and it’s not logging any drive faults. I’m leaning toward EEPROM chips or a bad board.
I was hoping maybe someone else has a similar problem.
I had to leave for the day MX4. I’ll be back at it in the morning and will let you know.
MX4 Offline
I’m no Otis guru, the fault is saying that fire service operation has mismatch values?
Do you have gen2 manuals? If not I can send you them
MX4 Offline
You can try to clear block on drive if any and dsp
Have you cleared pf ram?
MX4 #37418 05/07/24 01:41 PM
Z
Z Offline
Can you shoot the gen 2 manuals my way? [email protected]
Sorry on the late response. I do have the GEN 2 manuals. Thanks MX4
The mismatch faults are being logged because of the inability to properly set the bottom floor to 001 per the manual. I was told by an Otis adjuster friend that I would get these faults until I was able to change several software chips that are malfunctioning. I have the chips on order and will update everyone if this fixes the problem.
Thanks for your help, guys.
Anytime you have parameters that change on their own, it’s a safe assumption the Batram chips are going bad. Hope new ones get you headed in the right direction.
Not baT ram! ocss software needs to be recopied with data man
The gen 2 has bat ram chips.....? Thought they were eeproms?
MX4 #39686 06/21/25 04:17 AM
Hi any chance you can send me the manuals? Just got a job with one, no prints or manuals on site.
what sinister1ca said. i'm guess this is an "original" gen2, in which case it has eeprom on RCB & battram on MLB
MX4 #39856 07/27/25 07:41 AM
hello MK4, please I also need the gen2 manual... I'll be very grateful if you could help me with it.... thank you
MX4 #40407 11/26/25 11:42 PM
Can you send me the gen2 manuals I’m having an issue with a 710 drive fault
Gen2’s have battram chips on the MLBIII processor board and EEPROMS for software. The same type of EEPROMS are in the OVF30 drive as well.
If you type in otis gen2 adjustment manual in google several results come up on scribd.
You’re going to need OCSS / MCSS / DBSS if you want to be able to troubleshoot these things without help.
Gen 2s dont have mlb3 boards. Thats a 411. Gen 2s are GCS boards.
Early gen2s definitely use MLB3 boards with OVF30 drives. they didn't go GCS until around 2009/2010
We have "Gen 2 with 411 controls" but they're in a 311 cabinet. They are over slung belted cars with the machine and gov in the overhead
Page 1 of 2 1 2
PHP: 8.3.33 Page Time: 0.032s Queries: 55 (0.014s) Memory: 3.1148 MB (Peak: 3.5925 MB) Data Comp: Off Server Time: 2026-09-20 23:59:29 UTC
