#37514 05/30/24 05:17 PM
I'm Having intermittent 0072 fault on a KCM831 two stop. I have swapped sensors, checked magnet and sensor setups multiple times with shaft setups. It will run for about a week then it will come back in. I'm looking into replacing the LCECCBN2 next. If there is any other ideas please let me know.
Thanks!
MX4 Offline
If you have checked magnets, magnet distance, shaft setup, switch gap, switch then yes CCBN board could be failing
Also, might be the travel cable issue, you can swap the wire that carry it signal for check.
PHP: 8.3.33 Page Time: 0.023s Queries: 20 (0.005s) Memory: 3.0031 MB (Peak: 3.5923 MB) Data Comp: Off Server Time: 2026-09-21 06:19:47 UTC
