0 members (), 27 guests, and 1 robot.
#37553 06/06/24 12:38 PM
TKE 2 stop twin post.
Bouncing in up towards top landing.
I bleed cylinders
Clean valve filters
Zero trim valve.
Little better after this.
Next step to stop bouncing in up direction?
Change packings?
Any ideas?
Do you have plenty of oil in the tank when it gets up that high? Sometimes if theirs only an inch or so over the pump and motor when it's at the top the suction from the pump and the oil bypassing in the tank causes turbulence and the pump can suck air causing it to bounce. I'm not sure packings would be next on my list. The tight packings I've had usually cause a hard initial up start or a bounce in the down level or a really abrupt down start. Have you tried putting it down on the springs to resync the pistons? And you can try some maxton or cat hydro oil additive too I you think it might still be packing related. It's cheaper then doing a packing if the customer doesn't want to pay.. hopefully something here helps
Does it bounce while on inspect running up as well? I have one that does..plenty of oil. Might add some slick to the tanks as mentioned above. I hate these things. Next step I guess is the air bladder then Bucher valve.
Oil your rails, speed up your up level speed slightly
W Online: Content
I would check the "P" sol & "I" Static & Dynamic settings in the up direction and try adjusting them. I have seen this before with the Bucher valve.
V Offline
I have seen the tank vents not allowing enough airflow causing bouncing in the up direction.
@Vatorfixer so what was done to the vent to allow more air?
V Offline
I think the filter was plugged. I thought that they’re there to keep the oil smell from the hoistway and the tanks are bolted and gasketed so water can’t enter the tank (just my thoughts). I think the tank size is supposed to be adequate for the amount of air needed, but it seems like even some conventional machine room tanks seem to oil can from not enough air. I just wanted to add a problem that I had seen to the original post about bouncing in the up direction.
Another Helper
Another Helper
what about checking your zero point
PHP: 8.3.33 Page Time: 0.023s Queries: 33 (0.007s) Memory: 3.0355 MB (Peak: 3.5923 MB) Data Comp: Off Server Time: 2026-09-21 02:45:08 UTC
