October
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
10,053 Registered Users
Topics7,404
Posts41,025
Members10,053
#37736 07/13/24 05:52 PM
Hi Any sizing specialists in here.
Finished Shaft Dimensions
6’9” by 9’
3 stop front opening only twin roped hydro
Can I fit a 3500lb cap car in here ?
What would my max door opening be ?
Jluff #37738 07/13/24 09:23 PM
On the Alliance Elevator Solutions website they give rough dimensions for all of their equipment. A 3500# front opening twin jack holeless shows a hoistway dimension of 8'4" W x 6'11" D. A 3000# front opening twin jack holeless shows a hoistway dimension of 8'4" W x 6'2" D.
Jluff #37743 07/14/24 07:22 PM
Good Afternoon,
If the hoistway dimensions provided are 6'-9"Wide. x 9'-0"Deep. (door being on the short wall). Recommended sizing as follows:
Hoistway: 6'-9"w. x 9'-0"d.
Platform: 5'-0"w. x 8'-2"d.
Inside Car: 4'-8"w. x 7'-2"d.
Based on interior SQFT this car size is under the max allowable inside area for a 3500lb car.. which code allows. Depending on jurisdiction, it may not be required but this car sizing will accommodate a 24" x 84" Gurney.
- These dimensions are based on a 42" Two Speed Side Opening door.
If the hoistway dimensions are flipped; 9'-0"w. x 6'-9"d. Recommended Sizing as follows:
Hoistway: 9'-0"w. x 6'-9"d.
Platform: 7'-4w. x 6'-0"d.
Inside Car: 7'-0"w. x 5'-2"d.
(Still under max allowable inside area for a 3500lb car)
- With these dimensions you could fit the following door arrangements:
42" Single Speed Center Parting - NOT Stretcher compliant
48" Single Speed Center Parting Door - Stretcher compliant
42" Single Speed Side Opening - Stretcher compliant
- If a larger door width is required a multi speed panel arrangement would be needed.
These dimensions are based on standard running clearances, deductions for cab walls/interiors, etc. Final platform and interior dimensions could vary slightly +/- 2" approx.
Hope this helps.
PHP: 8.3.35 Page Time: 0.099s Queries: 20 (0.030s) Memory: 3.0047 MB (Peak: 3.5923 MB) Data Comp: Off Server Time: 2026-10-11 03:34:40 UTC
