I know a lot of companies are using the NSI connectors for motor lead lugs and line splices for larger wires. I just want to let you know if you push the wire into the connector too hard it could push through the other side breaking the insulation and exposing the conductor. I've seen this twice now and one time was a 480 volt motor connector. It makes a big flash!
