#38062 08/22/24 02:29 AM
Got an Otis LRV on the springs. Can’t run up. DR relay is picked. In ground jack. Sent relay and controller board off for repair. Got them back from repair, still nothing. Voltages and fuses are good. Any suggestions on what next?
wltr00 #38063 08/22/24 03:32 AM
If you ground the pm and umv contacts will the car move up? Need to check your 9vdc doesn't have any ac current on it
wltr00 #38066 08/22/24 05:02 PM
I was able to get it moving energizing the up coil and pushing in on the wye contactor but still won't run on automatic or inspection. I've also checked the limit switches and they are all good.
wltr00 #38067 08/22/24 05:24 PM
wltr00 #38068 08/22/24 05:25 PM
It needs the PM relay to fire for it to run, but no matter what I do, I can't get it fire
wltr00 #38072 08/22/24 11:59 PM
Check your DCL, it has to be open for car to run.
wltr00 #38073 08/23/24 01:03 AM
The controllers are shitty to work on. I don’t take them on unless the client is ready to rip it out and do a mod. No help to your situation besides the simple truth. Waste too much time and the clients money. The tanks can usually stay .
wltr00 #38074 08/23/24 01:52 AM
If you have good voltage on A1 of the PM coil and you ground A2 on PM and it'll pull in then you have a processor issue
PHP: 8.3.33 Page Time: 0.025s Queries: 30 (0.005s) Memory: 3.0299 MB (Peak: 3.5925 MB) Data Comp: Off Server Time: 2026-09-21 04:36:22 UTC
