#38090 08/24/24 07:53 PM
Good Afternoon,
Any one know off top if the KCM's are capable of Sabbath Operation. I haven't dived too deep into some literature I have, but was asked by a customer for a few Jewish clients they have coming in town in a few weeks or so. I don't know the exact date nor can I say what the Holiday is actually called.
Nonetheless, is there a parameter anyone knows or sequence they can share if again these controllers are capable.
As always, appreciate any help
Theirs probably a better way of doing it but if you go to menu 4_21_10.. then you use the door open button to program the floors you want it to go to. If you press and hold door open button for like 3 seconds that will start the programming then you press and hold for like 3 seconds each car call you want it to go to in the order you want it to go then press and hold door open button for like 3 seconds to end the programming. Then you put it to 4_21_9 to run the patterns.
I don't remember I you need to cycle the power to set it or if you want to reprogram it you have to cycle the power
There's another way to do it using the 3 menu if it has a lcecpu561.. if you pm me I can send you some info I found
Hey Bowtiedrooster16,
Yes it's a LCECPU561. I sent you a PM. Thanks a bunch
I didn't get your pm, but I sent you one with some info
PHP: 8.3.33 Page Time: 0.020s Queries: 26 (0.005s) Memory: 3.0195 MB (Peak: 3.5930 MB) Data Comp: Off Server Time: 2026-09-21 14:16:50 UTC
