10,097 Registered Users
Topics7,432
Posts41,135
Members10,097
#38097 08/26/24 12:50 PM
S Online: Content
Had two entrapments exactly one week apart (Friday evening at a hotel) Both passengers reported a knocking noise before elevator stopped. The fault codes were 94 with two sub codes 01 and 75..... 01 is CDOOR coil active when doors fully closed, 75 is CDOOR coil active with doors fully open. Not sure that make sense. The print shows that as long as the gate is made up the CDOOR coil should be active. Went over door locks, gate switch and checked terminals. No smoking gun. Elevator runs fine, but do not want to turn this over. Any suggestions?
solidstate #38098 08/26/24 03:29 PM
MX4 Offline
TouchOfTheTism’
TouchOfTheTism’
Sounds like the relays are failing on the board, if you get the board repaired see if the company will socket the base so if this happens again you can change the relay instead of sending it out for repair.
solidstate #38105 08/27/24 02:36 AM
I had to send a 2Q board in twice to get rid of a Xtra info 10. It wasn't the relays it was the IC13 chip.
solidstate #38108 08/27/24 10:20 AM
MX4 Offline
TouchOfTheTism’
TouchOfTheTism’
Sorry I got ahead of myself, I thought we were talking about a CRIP board on a 330A!
solidstate #38109 08/27/24 11:32 AM
That's the version of the cripna
PHP: 8.3.37 Page Time: 0.034s Queries: 24 (0.012s) Memory: 3.0180 MB (Peak: 3.5947 MB) Data Comp: Off Server Time: 2026-11-25 02:21:49 UTC
