Posts: 1 |
Hey everyone I’m looking for some info on programming HN boards on a Tac 32. When I perform a DHNF it show all 4 HN are offline but also shows floor 1 and 4 have a zero where the floor number should be. Has anyone encountered this before ? Tried TECCR , TECC , TECF and still the same. On the Car 2 it’s shows the correct floors and ports. Any help will be great thanks
Another Helper
Another Helper
Posts: 29 |
TECCR, TECC,TECF/R (FRONT AND REAR ACCORDINGLY), TECC, TECC, WRT
Posts: 359 |
you can also try TECB. It is used to toggle the Teach direction. Top Down or Bottom Up. Depends on where the HN terminating resistor is placed. If it is in the top HN, you would teach bottom up. IN the bottom HN, you would teach top down. Everytime you enter TECB it toggles the direction.
Another Helper
Another Helper
Posts: 29 |
have you checked you hall can voltages
