October
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
10,053 Registered Users
Topics7,404
Posts41,025
Members10,053
#38319 10/04/24 08:42 PM
Have an Otis 411 with corrupted software will no longer let me change parameters. Have contacted unitech to get new chips but they say they can't preprogram them and I have no other units to copy the software from. Anyone might have some software and could help me out?
I once had this problem on an 411 and just copying them to new chips fixed it.
Even with them being corrupted I can still use the software off the old chips?
It worked for me but it was like 10 years ago
There's three different types of chips on an Otis E411 RCB II board which is the OCSS in the system. I am assuming you are talking about that, rather than the MCSS or other components with software in them.
There are always two EPROMs that contain the standard "baseline" software for the OCSS. These are locations Z37 and Z52.
There MAY be two additional "contract software" chips, which are also EPROMs with job-specific software for adding customer-required features to the OCSS. These are locations Z36 and Z53.
The EPROMs will have an opaque UV-proof sticker on them that should have the software version printed on them. If not, you should be able to use the Service Tool (black) or Otis Field Tool (blue) to access the software version information. With that information, you should be able to get a copy from Unitech (assuming they will sell it to you). Or, you should be able to copy the chips from another E411 car's OCSS assuming it has the same version. Often, maintenance companies will take a snapshot of the chips contents as a backup, so check with your company office.
Normally if the EPROMs are corrupted, the OCSS won't run, or you will experience random resets of the RCB II when it tries to execute the corrupted software routines.
In addition, you will always have two contract data EEPROMs. These are locations Z34 and Z49. The data in this sets the configuration of the OCSS. If you don't have a backup, you can start with a copy from another job and try to reconfigure the data to match the affected elevator's configuration. There are a LOT of parameters and this is not for the faint-hearted. The I/Os will be shown on the diagrams, so you can definitely see what ones are used and figure out what address and pin they are using, but you'll still need the OCSS documentation to know what I/O numbers each of them are in order to set them up.
If your EEPROMs go bad, which can happen because of excessive writes, you should be able to copy them to a fresh set of chips. It's possible that whatever data location(s) can't be written may have slightly weird data in them, depending on what exactly went wrong when they were last written to.
Good luck!
Ya I should’ve been more specific. In my case, it was the EEPROMS U20 & U21 on the MLB3’s CPU. Still have them archived so was able to check. I want to say it was MCSS parameter Velocity Normal that kept changing to a huge number. All other parameters were fine so after copying to new chips we could set it to the right value.
Sounds to me like you have an EEPROM problem too. Could be OCSS or MCSS depending on which parameters you aren’t able to change.
PHP: 8.3.35 Page Time: 0.052s Queries: 26 (0.013s) Memory: 3.0211 MB (Peak: 3.5922 MB) Data Comp: Off Server Time: 2026-10-11 03:35:01 UTC
