Hello,
Was trying to do the 125% test on a mono 500; loaded the car up, inhibited doors and calls, then sent it to run one floor down to verify the elevator could handle the weight at contract and leveling speed. It got up to contract speed fine, but when trying to level into third floor it stopped. Attempted to run it down on MR to get it into the floor; but after a few failed attempts to get it to move it stopped trying to turn, even with a drive down command hi. Drive need is hi, drive ok is intermittent, elevator is lost and trying to sync.
Any idea what I did wrong and how to fix it?
BRG Offline
Need to clear the errors and try to run. What errors come up? There are many things you're leaving out.
Also check the sub code.
when error code appear push the select to show the sub cod to you.
PHP: 8.3.33 Page Time: 0.020s Queries: 20 (0.005s) Memory: 3.0035 MB (Peak: 3.5925 MB) Data Comp: Off Server Time: 2026-09-21 03:32:14 UTC
