#38566 11/21/24 04:22 PM
I have a Tac 32 hydro and I'm getting a 1705 fault it says :
EPD end of run test failed- safeties TFR to reset. I've tried a new Cpua board, an IOD board and still the same issue. Has anyone ever come across this issue?
T.Pope42 #38568 11/21/24 09:55 PM
Do you know what IO it’s not happy with? The fault description says if you flip it on then off inspection it should tell you which IO is the problem in Remote FAST. May tell you in response to the FLT command too but not sure.
T.Pope42 #38571 11/23/24 05:57 AM
I just had this the other day, try checking your selector magnets and make sure there are no gaps.
T.Pope42 #38572 11/23/24 02:50 PM
I have no gaps in my magnets and my polarity on the magnets is correct too. South pole on slow downs at the top and north pole at the bottom. When it goes through the safety check it drops tsrcpu. After It will bring chktsr, tsrcpm, ntsnpm,
PHP: 8.3.36 Page Time: 0.037s Queries: 22 (0.010s) Memory: 3.0119 MB (Peak: 3.5926 MB) Data Comp: Off Server Time: 2026-11-05 22:44:42 UTC
