Hey has anyone or anyone they known been able to use an Allen Bradley 1771HD Pendent, in place of a DMC Fast Tool? What was needed to get it to communicate with the 25 Pin D-shell conenctor. Is it just a RS485 to RS232 adapter? Will this allen bradley be able to read, understand, and communicate with DMC? I was recently assigned a couple on my route and have a kone company laptop with DMC SOFTWARE but is limited and sluggish. I know little about what the DMC is sending out of the 25 Pin D-Shell connector beyond the 24v supply or what this Allen bradley 1771HD and it uses an RS232 connector.. .
I have access to one through a family member who used to do PLC programming and retired, he's willing to part with it.
Any information or help will be a big help, also I hate dragging the laptop out of the van if I don't need to.
Using random picture from ebay as reference.
Regards,
Local 19
Rotte
Also, I have a dmc 25DB RS232 to RS232 9 pin adapter
MX4 Offline
TouchOfTheTism’
TouchOfTheTism’
I would like to know also, keep us updated please!
Have you actually heard of this working or are you asking just because it looks like a FAST Tool? That’s a generic enclosure that Dover used for the FAST tool. I think I’ve seen Schindler HHTs in the same one. It’s not a dumb terminal, it has a Dover made board inside that runs Dover software.
I've seen posts on other forums that it can possibly work with the correct hardware to convert the io data but I'm unsure. These communicate with Motion Control IMC Servo Control System Modules from Allen Bradley which communicates on a basic RS232 serial port platform. There is limited data concerning the tool and it's general makeup but I need a detailed schematic of the handheld device and general idea of what it normally reads.
They make all this so proprietary I can't dig up any schematics or data regarding the internal workings of either the Fast Tool or this Allen Bradley. If I had more time and attention span I'd attempt to reverse engineer Kone's KST DMC tool to understand the coding and how it communicates but two small kids and a wife dictates my time otherwise. Also, I've been mainly wanting to poke around KST exe files with a reverse engineering app.
I've heard this is a similar converter used by Thyssenkrupp at some point if anyone can confirm?
That converter was an alternative to the “orange cable” to convert from 232 to 485 for the old Dover DMC laptop program. It required a special driver to communicate with a DMC too.
PHP: 8.3.36 Page Time: 0.025s Queries: 33 (0.007s) Memory: 3.0360 MB (Peak: 3.5927 MB) Data Comp: Off Server Time: 2026-11-05 01:32:23 UTC
