#38850 01/24/25 03:45 PM
We have a KONE AMD 10 Drive board that keeps blowing the 5 amp fuse when power is plugged in. We have all other connections removed to isolate the problem. A new board is on order, but now the car next to it has the same issue. A second board is now on order. Has anyone seen this problem with the AMD 10? Is there a component on the board that is known to cause this that we could replace? The job has been running for a few years without issue.
Any help or advice is greatly appreciated.
yes, there is a protection diode that causing this problem, easy to repair.
If you send me the picture of the PCB, I can circle it for you.
https://share.icloud.com/photos/063wPR1c0LhrTMWOElwzmjXYw
Here’s the board - for anyone that’s curious.
MX4 Offline
Can you show me please?
I have the same problem. Can you tell me which component is damaged?
Still waiting to hear back from project.elevator. I tested the diode networks that I thought would be the issue but they were good. I'm curious to see if they point out a different component.
PHP: 8.3.33 Page Time: 0.021s Queries: 26 (0.006s) Memory: 3.0183 MB (Peak: 3.5923 MB) Data Comp: Off Server Time: 2026-09-21 04:29:58 UTC
