October
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
10,053 Registered Users
Topics7,404
Posts41,025
Members10,053
#38851 01/24/25 08:22 PM
Office has a couple of AT400 door operators that need to be replaced and want to use the GAL Omni operator. Anybody have any experience with these operators or any other recommendations to replace the AT400? Thanks
wltr00 #38852 01/24/25 09:16 PM
Question: What sort of controller and interface (discrete/serial) does it have to the AT400?
wltr00 #38853 01/24/25 09:50 PM
JJR Offline
The Omni operator w/nexus drive is nothing more than a rebranded Monarch Nice 900 (Delta VFD-DD similar) modified to GAL/Vantage line voltage/logic hookup specs. The params are identical to the Monarch/delta original in terms of purpose, but renamed to GAL specs. In other words, if you've ever worked on a Nice 900 or VFD-DD, it should be a breeze.
If I had my way, I'd just get a Glide A and get it over with.
wltr00 #38868 01/27/25 11:27 PM
The new Otis operator Glide A will retrofit the AT400 very well, I would definitely do that over the Omni. Only issue I have seen with the Glide A is it doesn't always learn door speed correctly. you sometimes need to use a service tool to adjust the speeds.
wltr00 #38871 01/27/25 11:55 PM
The new drives and motors GAL are using are not the best right now. They may get it fixed soon, we just went through 2 motors and 3 drives on a 4 car group that we moded. Bad right out of the box. We did get the Glide a for a 6970 that we are keeping the controller and replacing the operator. Used Otis, since they had the interface board and will hopefully be easier than the that Omni. Omni concept is great, they just need to get their quality up to speed.
wltr00 #38875 01/28/25 03:44 AM
MOVFE great option
wltr00 #38878 01/28/25 04:08 AM
Not familiar with the Omni but can say Glide A is 1/3 lead time of any GAL operator if that's a factor. I ALWAYS push to upgrade an Otis operator for an Otis operator, just cleaner upgrade and GAL quality has gone down as solidstate points out. Hope that helps.
wltr00 #38880 01/28/25 04:50 PM
JJR Offline
The real problem with GAL/Vantage is that they still make those old style mechanical link driven (harmonic) operators, such as MOVFR. They need to stop for many good reasons. All other companies have long stopped making harmonics. These reason are why most other countries have ban the use of such operators. I do agree that GAL makes good linear operators, like MONXT, which is very similar to a Fermator mechanically, but better built. The only drawback is that it's very new to the industry and may still have minor bugs.
Reasons why I absolutely hate mechanical operators:
1. The dangers of the gate switch. They can get inadvertently or intentionally pressed, compromising the safety system. Not all jurisdictions require DLM. Even with DLM, it can still be problematic. The lift could go out of service trapping people on upper floors who can't walk stairs, especially in high-rise apt buildings with only 2 lifts. The new-style linear ones have cabin door interlocks (no gate switch), making such situations impossible. Here's an ex. of what I'm talking about. Be glad this one had DLM. https://www.youtube.com/watch?v=AEOkZDBCDiw
Being able to spit the door at floor level is also bad. Pranksters are capable of manually separating the doors compromising the lock system, or sticking feet in door at final end of close cycle. This can also happen if a spring or roller is weak and the door strikes an object. This scenario can be dangerous if jumpers are left behind and no DLM installed, or case a system shutdown w/DLM. Non-splitable doors resolve this. Ex. https://www.youtube.com/watch?v=ZZ6Izd0TnRU Imagine if a jumper were on that hall lock. PS: The original idea behind splitable doors was, back in the day, there was more moving parts on the door panel, such as push-bar door retractor. With the Euro style, nothing is mounted on the door panel but the feet.
2. With the presence of interlocks, restrictors are no longer necessary. Harmonic operators do not support cab door interlocks and many types of restrictors can easily be disabled/bypassed by mechanics compromising passenger safety. Worse yet, those electronic restrictors like hatch-latch by Adams can fail in the locked position and are prone to sensor misalignment and dead batteries during power failure. These were responsible for many fatalities at WTC on 9/11, where Othis 6940 locks were used. For this reason, they could only be released from cab top. On new installs (especially all glass), no ugly expensive sheet metal is needed between floors.
3. During entrapment, Harmonic operators can become self-locking (operator can move the doors, but doors cannot move operator). This situation requires rescue workers to have to get on the cab top and spin the infamous wheels, this can be problematic in situations where the lift is on the top floor or in the case of a steep drop (i.e train station, garage). Linear door operators never become self-locking. Once interlock is released (can be done at floor or top), door can be manually opened from both floor level and cab top. Also, if lift stalls at floor level, no triangular or drop key is needed due to the spring loaded clutch. All you gotta do is push open the door. See examples below.
Self-locking ex. GAL: https://www.youtube.com/watch?v=9TnHnKU9EnQ
Self-locking ex. MAC (0:36): https://www.youtube.com/watch?v=TcdMfuUJprk
Linear difference: https://www.youtube.com/watch?v=eyjQC7llJkE
4. Use of Harmonic operators on full glass door panels is not only more expensive due to construction costs, but a fall hazard for mechanics. Operators propped up on pedestals pose fall hazards for workers due to a steep drop from the operator to the cab top. New-style linear operators eliminate this as clutch is mounted on roller header instead of doors. This also increases installation costs as more overhead is needed. Worse yet, big money has to be spent on ulgy tackly looking sheet metal between the floors. All this is solved by Euro style linears.
These are the main reasons OEM companies stopped producing harmonic operators. They don't want to get hit by lawsuits involving their lower safety record.
PS: At least Schindler is smart enough to use Fermator and Sematic. Fermator and Sematic are the "Energizer bunnies of door operators." They keep going and going and going. Those old harmonics from GAL, even when installed new, be falling apart after just a few months. Worse yet. Those crappy nylon roller requiring oil wipers suck and are noisy. The others use polyurethane.
wltr00 #39057 02/24/25 01:50 AM
I have done a few swaps on the AT400 with a glide A easy swap .
PHP: 8.3.35 Page Time: 0.046s Queries: 32 (0.009s) Memory: 3.0418 MB (Peak: 3.5923 MB) Data Comp: Off Server Time: 2026-10-11 03:34:42 UTC
