#38972 02/10/25 04:53 PM
I am having a issue with the door disconnect. When I change D-26 from a 1 to a 0, it just goes back to a 1. Before this happened, I had to replace the cpua for a separate problem. Any suggestions would be greatly appreciated.
King2Elev #38973 02/11/25 12:06 AM
I can't recall for sure. But doesn't a 32 have a physical door cutout switch on the board? Maybe it's hit?
King2Elev #38974 02/11/25 12:17 AM
Yeah it could be the DD switch. Work it a little. Maybe stuck or defective
King2Elev #39129 03/08/25 05:37 PM
Was this after a new hoistway scan? Have you performed NTSD test at top and bottom? Generic software version 7B I think does not allow you to successfully complete an NTSD test so you would need to upgrade or downgrade, perform NTSD then change d26.
King2Elev #39245 03/25/25 11:37 PM
O
O Offline
Are changing d26 on ims? If so it should show a message. Like 420 said to learn ntsd or some other reason
PHP: 8.3.36 Page Time: 0.029s Queries: 24 (0.010s) Memory: 3.0153 MB (Peak: 3.5927 MB) Data Comp: Off Server Time: 2026-11-05 20:09:53 UTC
