I can't believe your company charged you for prints, they are on the manufacturer's web site and available for free to distributors. Yout TK run button wont work, but you can make one easy enough. IT's just a standard 5 pin din input, lower right corner of your board. Pin 1 is term 24V , Pin 2 is term 35 , Pin 3 is your Fast Speed, Pin 4 is down and Pin 5 is Up, So pin 1 to pin 5 will give you up slow , pin 1, 3 and 5 will give you up fast. Pins 1 and 4 will give you down slow and pins 1, 3 and 4 will give you down fast. You can use pin 1 and 2 to power a wireless remote, that way you don;t need to deal with the cord. Once yo add pressure to the system, the safeties should be disengaged and the slack cable switches will reset.
