10,097 Registered Users
Topics7,432
Posts41,135
Members10,097
#39763 07/08/25 02:07 PM
I have a Tac 32 that's ups unit has to be manually turned on ever time to fire up the controller after a power loss.
I tried replacing batteries in ups unit with no change.
Was wondering if anyone has experienced this problem before.
Thanks for the help!
Shane5e #39790 07/11/25 01:39 PM
So it turns on but then shuts itself off later? So when power goes out you have to re turn on?
Id check and replace batteries first if not then replace the ups.
Voltage testing the batteries is a bad test. You must load test the batteries. A car battery load tester is cheap and extremely effective for this. The carbon pile kind with the switch you press and hold after clipping on the battery with the analog voltmeter on the front
Shane5e #39811 07/16/25 07:59 PM
We replaced the batteries with no change. The next thing we are going to try is to replace the stby2 relay and hope that fixes it.
The ups seems to work fine. Just when the power is returned to the controller due to a power outage or cycling of power the ups unit does not want to fire up. You have to manually turn the unit on.
Shane5e #39812 07/16/25 11:17 PM
Another Helper
Another Helper
sounds like a bad ups
Shane5e #39813 07/16/25 11:58 PM
That’s normal… There is no circuit to make the UPS turn on when you turn on the disconnect. When you turn off a TK hydro with a UPS you have to manually turn the UPS off or it’ll beep saying no power. Then when you turn on the disconnect you have to turn on the UPS to put power to the controller.
Shane5e #39815 07/18/25 02:24 AM
Makes sense. The otis units and older dmcs you have to go to the machine room and turn a keyswitch after the powers out to activate battery lowering
Shane5e #39816 07/18/25 11:32 AM
All my 32s fire the ups back on, what would you do for a mrl then?
Shane5e #39817 07/18/25 04:45 PM
I don’t know I’ve never seen one
Shane5e #39818 07/18/25 11:03 PM
Consider yourself lucky, you have to run it on the recovery pump at 1 to 2 fpm till you can access the cartop and get behind the controller to the ups.
Shane5e #39823 07/19/25 02:53 PM
Oh I do. California is not so bad.
Indirtwetrust #39827 07/19/25 07:20 PM
Dirt, are there no MRL's of any kind in California?
Shane5e #39828 07/19/25 11:01 PM
No literal MRLs. We do have machines in the hoistway but still has to be at least a closet for the controller and drive. No drives in the hoistway, controllers in the jam, and no MRL hydros.
Indirtwetrust #39829 07/20/25 01:07 AM
Wow, that's great!
Indirtwetrust #39835 07/21/25 10:47 PM
InDirt, that almost makes me want to move to Cali. Almost.....
PHP: 8.3.37 Page Time: 0.037s Queries: 42 (0.012s) Memory: 3.0648 MB (Peak: 3.5946 MB) Data Comp: Off Server Time: 2026-11-25 02:01:22 UTC
