Posts: 15 |
Thanks in advance. Otis 211 Phase 2, it is in fault fslr, the selector signals are good in the I/O board, i need to change some parameters but when i reset the controller the parameters go to preview number. No Service Tool can talk with the elevator ( i dont know why) i have tested four diferent Service Tool in both elevators. So, how to put in off the write protection from the controller, i suppose it is what avoid to change the parameters.
Posts: 71 Likes: 2
Posts: 71 Likes: 2 |
copy parameter chip onto a new chip. software version is too old, need AAJ or newer.
Posts: 15 |
The version is AAI, Where can i find the newer version? it is suppose i should contact to OTIS, Correct?
Posts: 15 |
Where connect the service tool in otis 211 phase 2? I see only Diagnostic connector and the ST doesn’t work there. Others models have Diagnostic and ST connector. If I connect the ST in Diagnostic I get the same result in any model, so Diagnistic isn’t the correct one for the ST. Does 211 phase 2 use ST?
