BSP
BSP
everyday my schindler escalator shuts down with a e35 saftey brake error.changed all service and saftey brake soleinods.and changed all associated relays. what the heck.is can anyone help me in this situation? please help!!
MBKE
Did you ever resolve this.
I know Schindler had a problem with the reliability of the safety brake mechanism, which contains a solenoid and also the monitoring contacts. Is it possible that the cord coming out of the safety brake is rubbing on a chain?
While performing a handrail replacement on a 9300, I found 2 wiring bundles that were slowly wearing on the step chain and, were it not found, would have caused a problem shortly.
Len Offline
You didn,t specify if it was a SWE or Swu..model..when I worked on those in the past the location of the Starting Station was mounted in the incline decking..yes while remove decking to work on the handrail drive system..the wiring for this has a tendency to drop down and rub against the moving stepchain..this has been a problem from day one wiring gets broken and even shorted out.this is also followed by a 41 fault which is a dead giveaway direction failure which will drop the emergency Brake..Oh how i miss working on that stuff...
Might be time for their retrofit .. ummm good luck. ..you will need it
I'm pretty sure the SWU's and SWE's are their own breed. The next Schindler stairs were the 9300's. Totally different control, drives are very similar.
BSP
BSP
Its a 9300AE/10.(2007) Dual sync.drive. I have the new heat sink saftey & service brake solinoids installed from factory. Nothing elese wrong. no chain rubbing, new boards , new saftey brake capasitor and print combo. wierd!!!!
MBKE
BSP
BSP
found the issue.
MBKE
What was it?
BSP
BSP
Something in the controller is over heating . we have to keep a fan on the controller or it with set E35.
MBKE
PHP: 8.3.33 Page Time: 0.023s Queries: 34 (0.007s) Memory: 3.0416 MB (Peak: 3.5923 MB) Data Comp: Off Server Time: 2026-09-21 17:42:35 UTC
