#40262 10/20/25 05:22 PM
Anyone have a manual? I have one over speeding in the down with capacity. Need to adjust to pass inspection.
When you say that the unit is over-speeding, do yo mean that you are tripping the arrestor switch at the lower end of the unit??
I'd first confirm exactly what's triggering the overspeed condition before making an adjustment just to get it through inspection.
If it's only happening in the down direction under load, I'd be looking at whether the speed is actually outside spec or whether something in the governor/arrestor setup is causing it to trip prematurely. Condition and adjustment of the braking components would be worth checking as well.
I'd try to get the Artira service manual and verify the manufacturer's settings before changing anything. With a safety-related issue like overspeed, adjusting it by trial and error could create a bigger problem than the original fault.
PHP: 8.3.36 Page Time: 0.033s Queries: 20 (0.012s) Memory: 3.0043 MB (Peak: 3.5926 MB) Data Comp: Off Server Time: 2026-11-04 19:50:44 UTC
