0 members (), 72 guests, and 2 robots.
Topics7,434
Posts41,132
#40415 12/03/25 01:01 AM
I've been installing the Smartrise hydro controller for the last few years. It's cheap, it's quick. I'm looking for recommendations for another control system. I've been modding bare bone nothing fancy 2 - 4 stop hydros mainly old Dovers and Montgomerys.
JDJ Offline
Have you seen the Alpha controller yet?
JJR Offline
If you want to go generic, go with MCE, it's the most stable quality. The next best is VCI Vision. Stay clear of PLC, except JRT. PLCs aren't really designed specifically for elevators, they are more like general purpose relay controls emmulated by a solid state controller. While I actually would recommend them in hazardous locations like mine shafts and jails; however I would not recommend them for a group of elevators, the quality of the dispatching is like that of an old Westinghouse or Express lift, where they tend to go chasing after each other. You might could get away with just a single cab. They also require a lot of wiring, which is trial and error.
The company I work for has been doing similar installs, 2-7 stop hydros, with the eci pixel. They've been using them for 3-4 years now and they seem to be pretty decent. Theyve even started using the pixel for traction mods. The company likes it cuz you can order the hydro mods as a package with the controller already mounted to the tank and wired to the pump and valve. Tech support takes a bit to get back to you but has been ok at solving the problem. The controllers them self are laid out pretty decent fairly simple to wire. I really like the security board for car/hall lockouts mounted right in the controller so no extra travelers. Ive done limited mods, maybe a dozen (3of them pixel), and the eci seems like a solid new era controller.
I second mce and virginia as your most reliable. Its very hard to beat those two. Smartrise is a dumpster fire....
ESI (Elevator systems Inc)
Alpha
MCE
VCI
LA Elevator
LA Elevator
JJR Offline
If you wish to take more precautions, I would also recommend staying away from harmonic door operators. Read my post in this article, explaining the associated risks. https://www.vatortrader.com/forums/ubbthreads.php?ubb=showflat&Number=40360#Post40360
ESI is a simple, one page print traction or hydro. Low rise, basic elevators it’s very easy. One motherboard, that’s also affordable.
what is the advantage here? the few minutes saved of not having terminating wire? how often does the controller have to be removed to get it in the building/machine room? i always liked the controller being bolted to the front of the tank. some OEMs do ot better than others....
I would recommend Alpha for sure the best of what is out there today.
PHP: 8.3.37 Page Time: 0.037s Queries: 36 (0.011s) Memory: 3.0501 MB (Peak: 3.5932 MB) Data Comp: Off Server Time: 2026-11-22 17:15:51 UTC
