0 members (), 32 guests, and 3 robots.
Posts40,945
www.lift-spare-parts.com
Elevator parts
Elevator Tool
Elevator Button
Elevator Board
Elevator Roller
Elevator Belt
Elevator Door Parts
Guide Shoe/Gib
Elevator Buffer
Other Elevator Parts
Lift Spare Parts
Elevator Encoder
Elevator Light Curtain
Guide Rail
Door Operator
Hoistway Parts
Elevator Lock/Switch
Elevator Brake Parts
Elevator Indicator
Other Lift Spare Parts
Escalator Parts
Comb Plate
Escalator Step
Escalator Handrail
Escalator PCB
Escalator Chain
Escalator Roller
Demarcation Tail/Strip
Escalator Inlet
Escalator Light
Other Escalator Parts
toshiba PB-IPM200A
toshiba CV150 HIB-NLA Display
Thyssen 240 pcb
SIGMA INV-ACRA-1
SIGMA HBDC
SIGMA DCI-270
OTIS RCB 2
mitsubishi PM100RSE120
mitsubishi P235701B000G02
mitsubishi P231709B000G23
mitsubishi P231709B000G13
mitsubishi P203741B000G01
mitsubishi P203737B000G01
mitsubishi P203735B000G01
mitsubishi P203730B000G01
mitsubishi P203729B000G01
mitsubishi P203718B000G03
mitsubishi LHH-321A
mitsubishi LHH-320
mitsubishi LHH-20
mitsubishi LHA-022A
mitsubishi KM-A501 0310
mitsubishi KCR-943A
mitsubishi KCJ-400A
mitsubishi EISEG-106
Otis MCB3
LG 1R02148 B0
LG 1R01306 B2
schindler D2 BUTTON
SCHINDLER CONTACTOR MG6
Escalator safty brush 20*45mm
otis roller 56*16.2 FAA456X1
OTIS Test Tool GAA21750S2
Elevator weighing device switch
Thyssen Velino Inlet 80016100
Otis SM-04-VER
Sigma PCB dci230 3X03442A
Schindler Terminal KM59321501/KM59321493
schindler msr bi LOC Switch
Elevator INVERTER RESISTOR
OTIS 506NCE chain roller
Otis FAA25090J317 Button
Otis FAA25090 A314 Button
Otis Button FAA25090A2
Otis Button FAA25090A1
Otis assy AGA26800UD2 UD2
OTIS comb XAA4531
Otis 2000R indicator display
Otis 18ATF Machine Encoder AAA633L1
Elevator limit switch TR 236-11Z
Elevator light switch L3S-GS3E4
SIGMA MTD KA142 Button
LG message board DCL-243
LG Sigma OPP-2000 DOA-100
LG direction lamp HLV-630
kone Tachometer Km276027
Kone RTV comb plate
KONE LCEKNX D1 KM713130G01
Kone Handrail Inlet R20
kone corporation PCB 602800G01
KONE Elevator Tool KM878240G02
IGBT E78996 160MT160KB
IGBT No.S10DA4 CM200DY-24H
IGBT No.N64AA3 QM200HA-2H
Hyundai OPB 340 W10C0209 EFROM V3.90
Otis Step Demarcation Tail
hyundai comb plate L47312023
HONTKO Encoder HTR-HB-8-X202
hitachi board MCUB03-MCUB02
hitachi board FECDF21U1-MCUB01
light curtain Safety Edge
light curtain power unit
Weco light curtain 957M
light curtain 957E side opening
Weco light curtain 917G
light curtain 917F
light curtain 917A
Otis Guide Shoe Busher 150-33mm
otis guide shoe 20cm
Thyssen guide shoe 17mm
Fujitec guide shoe 11mm
Thyssen Rubber Handrail
Otis Guide Shoe Gib 200-35
Otis Guide Shoe busher
Elevator Door slider 64*14*35
Otis Door Slider Small
DAA25140NNP14 Otis Board
DAA25140NNP1 otis pcb
Bistability switch for door operator
Mitsubushi KCJ-100A
Otis GAA290CF2 77*23-6203
Elevator directive board SM-03-D
elevator car control panel SM-02-D
sigma LG INV-FIO-1
sigma DPD-05 3X02767-B1
AVY4185 SIEI INVERTER BOARD
SCHNEIDER CAE40 TESYS E
SCHINDLER XPZ 1400 Belt
SCHINDLER DOOR MOTOR MQKS9-6/12 950089
OTIS Test Tool GAA21750AK2
OTIS SENSOR HB1
otis Double rope door roller
otis RSEB communication board 9693AE1
LG SIGMA 1R01685-Bo INV-MPU
LG HDF-2 HDF-1
Kone Tooth Belt DEE3721645
LG/SIGMA Rotary encoder PKT1040-1024-C15C
KONE OPERATOR board KM606810G01
Kone door lock roller KM35939G01
schindler Escalator Roller 76-25
schindler 133.33 step chain
Schindler PA66-GF30 SMS405029 Roller
KONE KM5256442HO1 Roller
KONE 75-23.5
Kone Escalator RTK CHAIN
mitsubishi Roller 60*55
mitsubishi step roller 80-25*6204
hitachi wheel 76.2*22
hitachi chain roller
hitachi door hanger roller 67.5*14
toshiba door hanger roller J11.11F
Fujitec Step Roller 75*23.5-6204
Fujitec 75*23.5
fujitec Roller 75-23.5
Thyssen FT722 Transition Chain
thyssen FT722 Step Chain
Thyssen 1705060100 75*24
Xizi Otis XAA290CY 76.2*22-6203
Otis Roller GAA 290 CB2
Otis Roller G0290AJ11
Otis Escalator Roller G0290AJ9
Otis Roller G0290AJ3
ESD Escalator Chain
schindler travolator pallet 800mm
thyssen roller band insert 1737525800
Thyssen 722 step chain
SCHINDLER WALKWAY PALLET CHAIN
schindler SWE roller band
Schindler 9300 deflecting chain 409585
OTIS 506NCE STEP CHAIN
KONE RTV STEP CHAIN
Elevator Swing Door
Selcom Door Operator
KNOWHOW LANDING DOOR
KNOWHOW CAR DOOR Operator
Door Operator VVVF
Polyurethane Buffer B type
Polyurethane Buffer of Elevator A Type
Elevator Polyurethane Buffer all type
HEIDENHAIN ERN 1387 encoder
TK5A,Elevator Guide Rail TK5A
T90B,Elevator Guide Rail T90B
T89B,Elevator Guide Rail T89B
T82B,Elevtor Guide Rail T82B
T75-3B,Elevator Guide Rail T75-3B
T70,Elevator Guide Rail T70
T50,Elevator Guide Rail T50
THYSSEN STEP HP08330/1
Schindler Aluminum STEP 1000MM/800MM
MITSUBISHI Aluminum STEP 1000MM
KONE STEP 1000MM
STEP 3 PHASES SEQUENCES RELAY
DEE3710484 Step Pad for KONE
thyssen parameter test tool API/CPI
ELEVATOR Oil Cup/Oil Can
Otis Door Roller Rail G5NK924A
DOR-123 Mitsubishi Board (DOR-123)
Otis Floor indicator FDA23600V
ELEVATOR INTERCOM
IGBT Module QM200HA-2H
otis 506 Escalator Aluminum Step
Schindler Elevator Inverter
Thyssen 818 Demarcation Tail
selcom 3201.05.0058/c
KONE ROOMLESS KEY LOCK KM281629
Mitsubishi lift KCD-603E PCB board
OTIS GAA26810C2 PCB
oxford light curtain FCU35
lambda door unit otis ABA24591AC2
KONE TEST TOOL ENGLISH Version KM878240G02
Mitsubishi elevator door slider
mitsubishi KCD-600E
mitsubishi KCD-602
OTIS encoder JAA00633AAF001
I see where all our parts where made from.
Hello all! Where i can find instructions on Hyundai elevators ?
Speaking of parts from China:
http://www.ejinsight.com/20150810-8-rescued-after-lift-times-square-plummets-4-stories/
Times square is a class A building and Schindler maintains the elevators they built. How much do we want to bet Schindler Hong Kong was using China-sourced parts?
PHP: 8.3.33 Page Time: 0.020s Queries: 22 (0.005s) Memory: 3.0190 MB (Peak: 3.5928 MB) Data Comp: Off Server Time: 2026-09-22 14:46:34 UTC
