#40554 01/07/26 03:42 PM
Scrapwood99
Scrapwood99
Have a otis 211 trying to adjust close door force change the parameter close force max from 133 to 80 not much difference any other parameter that should be looked at or changed ?TIA
An Otis 211 is a controller type. What is the door operator type being used?
Scrapwood99
Scrapwood99
At400
Scrapwood99
Scrapwood99
At400
Write protect off
Are you plugged into the operator or in the controller?
Scrapwood99
Scrapwood99
Plugged in to the operator top of car I was able to change the door close force the default is 133 I changed it to 80 that's minimum setting not seeing change the inspector said to high
Scrapwood99
Scrapwood99
I how would u turn write protec off?
MX4 Offline
M181 I think is write protect
MX4 Offline
Or it could be M281 I can’t remember without being hands on lol
Its m-1-8-1 on newer stuff I think a 211 in m-1-61. But that's not the issue if you're plugged into the operator.
Do you have a pressure gauge to measure closing force?
Are you trying to change close force because it is over 30# for your annual test? This has nothing to do with write protection, Go to M-3-1-5 and post the version #
That is the correct parameter. If I recall there was an old version of AT400 SW. that did over torque and needed to be upgraded.
Would try taking readings at 130 and 80 and see if there is a difference. Just to make sure we are on the same page, to get the reading, with car on normal, place a call and stall the car door 1/3 of travel with your foot, apply gauge and move your foot.
Scrapwood99
Scrapwood99
Will try that if when I get back there it dose seem like there was no change in force after changing that parameter I'll have to bring tool back and re-check I do know I was able to change parameter it definitely saved new value even after remove tool clear faults and changed value remained changed.not sure of the version of at400 it was
the software should have been upgraded 15+ years ago. it's possible it never did especially if it got taken over by another company after handover.check the version # and post back here I can help you if you have the non-flash controller
PHP: 8.3.33 Page Time: 0.026s Queries: 44 (0.007s) Memory: 3.0648 MB (Peak: 3.5923 MB) Data Comp: Off Server Time: 2026-09-21 00:47:31 UTC
