I have a Schindler Miconic HX (321A)2-Stop Hydro that is throwing "Door Operator Error" 202 Xtra Info 06. This is the only fault I get.
I've replaced the door board, both D.O.L./ D.C.L. Mag Switches
I keep on losing SKD4, SKD5, andSKD6.
CRIPHNA2.0 Board. Original Board I believe.
All HSTWY/Car Door Tracks clean. Gate and Door contacts replaced and clean.
Can I replace with a CRIPHNA 5.0?
Could the CIO Board be an issue?
The door isn't recognized as closed and reopens or just reopens. Sometimes the door will stay closed. The Nudging Buzzer will go off regardless of position. No obstructions detected by the Cedes Door Edge until I break the beam.
Door motor (1/3hp) ohms out at 10 ohms. When I remove the Door Motor belt for the door motor (original equipment) the car and hstwy doors move open/close buttery smooth. When I reattach the door motor belt I have to struggle to close the door. Sometimes feels like bad door motor bearings, sometimes feels like something else.
Any input is greatly appreciated!!
