Topics7,432
Posts41,135
Members10,097
Posts: 19 |
I have a tac32 that faults about once a day trapping the same person each time. I want to set it up to run continuously from 1st to 3rd flooor and back again without risking a passenger, so I can test the elevator after it faults, without a POR. Anyone know a way to set this up?
Posts: 648 Likes: 1
Posts: 648 Likes: 1 |
Turn off door disconnect at IOE BOARD Set 061 to 1 Set M13 to 60
Posts: 19 |
Thanks, I have it running now, hoping it will fault over weekend.
Posts: 19 |
Came back Saturday, since I was concerned about overheating. Apparently M13=60 is actually 6 seconds. Set it to 300 and got 30 seconds.
Anyway, I found a half dozen faults mostly heat related and found the two faults I was looking for. 1530 and safety string open.
I checked the controller and then the selector, something looked odd so I measured and found the bottom slowdown magnet at the top floor had slid down 5 inches. It appeared to be glued in place. Pushed a little harder and got it to slide back in place, glued it down and ran a hoistscan.
It's now running random without doors, dwelling for 30 seconds at each stop.
Crossed fingers.
Posts: 1,769 Likes: 12
Posts: 1,769 Likes: 12 |
Posts: 19 |
The 1530 fault did not show up. Got 7 faults but was still running Monday morning. 2709, 1021, 2055, 1021, 2757, 2755 and 1926. Going to try reinstalling software as the last fault suggests.
Posts: 19 |
After reinstalling software, I'm getting 3 faults. 1926, 2755 and 2757. If anyone has a good idea, I would appreciate the help.
Posts: 45 |
Don't know the 2755 or 2757 but I'd guess it's an overspeed in the terminal slow down top or bottom. Do your faults give an explanation?
Posts: 90 Likes: 1
Posts: 90 Likes: 1 |
Both 2755 & faults are to do with your safety processor. 2755 is "SP False AC Peak detect Interupt" - check your wiring connections and more importantly your grounds. I can't remember off hand what 2757 is unfortunately. 1926 is your NP I/O mismatch with CPU. You might have bad software
Edit* Fault Code 2757 is: Selector CAN message timeout. Data from the Selector was not received in the alloted time. You either have a loose connection or noise on your CAN
J. Clark
Posts: 19 |
At this point I'm looking for software. I suspect there may be an issue with the version I have since I reinstalled twice and already went through all the connections I can find. The faults are a nuisance at this point, since it's not shutting down.
Posts: 359 |
You can type in “VER” in IMS to check your SW version and job SW to make sure it matches the job.
Posts: 19 |
After reinstalling the same software. I ended up with a single selector fault that would shut the elevator down for a few minutes while leveling to the lower floor. I went to the selector and found a 6" magnet that had drifted about 3" from the bottom of a strip of magnets. It appeared to be glued in place and with a bit of force i was able to move it back an silicone it in place. It's been running ever since.
Note: This failure helped me with a sister elevator in the same complex, it also had a selector magnet that had moved 1/4th inch at an angle. Sad that about 5 years after a modernization things are coming loose.
